Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower drive belt keeps breaking on my lt1000
I have replaced the belt but it broke again after about 1 hour of mowing
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
panilling9
  • 284 Answers
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Posted on Jun 07, 2009
SOURCE: Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
Posted on Jun 15, 2009
woobie dog
  • 1273 Answers
SOURCE: How do I tighten the mower belt on a lt1000?
It is kept tight by a tensioning pully. If it is loose, replace it.
regards, --W/D--
Posted on Jul 21, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Drive Belt on my LT166 John Deere riding mower keeps breaking. WHY?
Something in the space. Breaking the blades, a stick or etc.
Apr 18, 2014 | Garden
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Broke engine to deck belt after only 33 hours of mowing. Swisher needs to resolve this problem. Will they stand behind their products?
I also had the same problem, belts kept breaking after a short period of time, and the problem turned out to be the four bolts holding the engine to the frame loosened to the point the engine was tilting and letting the belt slip. Once new bolts with lock washers were installed, all has been good.
Sep 19, 2010 | Swisher Zt2350 Zero Turn Radius Tractor
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Mandrel on right side has broken 3 times have only done 7.3 hours
It sounds like your blade is hitting the ground when you are mowing.If you have high spots in your yard the blade will cut into the ground and the mounts on the mandrel will break. Make sure the mower rake adjustment is set correctly,the mower blade should be level or a maximum of 1/4 inch lower in the front.This adjustment is done with the adjuster bolt that runs from the front of the mower to the frame under the muffler, it may have one or two rods connecting the mower at this point. Also make sure the wheels are set down far enough so they can prevent the deck from scalping,they have five different mount holes,if they are up in the highest they will not do anything.Unfortunately these mower mandrels will not take a lot of punishment and they can break when the blades contact anything like dirt or tree roots. Your ultimate action may be just to mow the grass a little higher to keep from scalping. Hope this helps.
Aug 04, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 drive belt slipping
Is there the proper amount of tension on the belt?Look in your owner's manual to find out how to adjust the tension.
Aug 02, 2009 | Garden
Cub Cadet mowing drive belt often breaks or jumps the pulley
sounds like possibly burrs on pully, or pully depth is incorrect, causing belt to jump.
Jul 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Yard Machine posessed by devil
there are to belts the lower belt drives the blades ,the belt above it drives the mower that's mabey where your problem is.
May 23, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
