Question about MSI 945GCM7L (945GCM7F) Motherboard
945GCM7L (945GCM7F) Motherboard no display - MSI 945GCM7L (945GCM7F) Motherboard
  • joecoolvette
    joecoolvette Oct 26, 2012
    More than likely a bad Power Supply. Tried testing it yet, or substituting with a KNOWN to be good, Compatible unit from another working computer? Fans spin, LED lights light, means NOTHING. You could have a Power Supply with a weak voltage power rail.Enough power to power those simpy LED's, and fans, but NOT enough power for the Processor. 1) If ALL of the LED's were on at once, they would use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts. 3) A typical Processor can use 51 to 125 Watts. Just depends on what Processor it is.
Msi ms 7507 motherboard bios update
http://www.msi-bios.com/msi-bios-number-MS-7507.html
Mar 03, 2013 | MSI 945GCM7L (945GCM7F) Motherboard
Do not boot
have you check your boot setting ? if you are not so please check your system boot setting...
Jan 11, 2012 | MSI 945GCM7L (945GCM7F) Motherboard
Where is the outlet of the audeo
The light green jack on the back of the board is the Audio out jack. You will want to plug in powered speakers.
Aug 16, 2011 | MSI 945GCM7L (945GCM7F) Motherboard
Where can i get driver SM Bus Controller driver for MSI 945gcm7 motherboard...tq
Hi!
The SM Bus is part of the Intel chipset. Download and install it from here.
Make sure to restart after the installation.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
May 29, 2011 | MSI 945GCM7L (945GCM7F) Motherboard
Quiero usarla con dos monitores
Necesitas instalar una tarjeta gr?fica adicional, ya sea PCI Express o PCI, o un bifurcador de se?al VGA para dividir la se?al del v?deo integrado entre dos monitores.
Jan 10, 2011 | MSI 945GCM7L (945GCM7F) Motherboard
MSI 945GCM7L (945GCM7F) Motherboard Logo
62 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
