Question about Masonry Tools
How do I change drive belt on a craftsman 12 inch planer
How do I change the belt
4 Suggested Answers
  • 10865 Answers
SOURCE: craftsman planer joiner
go to sears.com and order the manual and/or part that u need.
Posted on May 19, 2009
SOURCE: I need to change the belt on a Roybi AP-10 planer
I called sears and they actually HELPED
Posted on Oct 28, 2009
SOURCE: where can I get new
Click on the link below to order a replacement set of 12" blades for your Ryobi AH115
http://www.amazon.com/PLANER-BLADE-SET-AH115-RYOBI/dp/B000P8QN8U
Posted on Jan 10, 2011
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Need a manual for Craftsman Contractor series 12 1/2 Planer #351.23383
Go to the Sears Parts Direct web site and search for the Planer model number. I got two results, the second one had a link for the manual. Here is a direct link: 351233831 CRAFTSMAN 12 1 2 PLANER MOLDER Manual
Jul 06, 2014 | Craftsman 12 amp 12-1/2" Bench Planer...
I need a vbelt part #18595.00 for a planer Mod # 351217403 from Craftsman. According to Sears it was mede by Soto P Clovis Co I can fnd them on the web, but all pphone No# given are not in service. can you...
Take the belt to auto parts store and ask them to measure and give you a belt. The clerk will ask you what it came off of. It does not matter a belt of that length is used in many different applications. I took a belt to AZ and asked for a belt and was asked did it come off of, I told him a 1947 Atlas Drill Press and he started looking for that not realizing that it was not a car. The manager and I just shook our heads. You can go to YouTube and view how to measure belt and go to ebay and buy one I have done both for belts
Sep 16, 2017 | Craftsman 12 amp 12-1/2" Bench Planer...
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
How do I replace the drive belt on my dewalt planer
Hi ladyccowboy1,
The drive belt is on the side with the handle (you might already know that :>)).
Take the top off, then remove the lifting gears. Remove the side cover. You'll see the cutterhead pulley that has ridges on it to keep the belt from moving in and out. Remove the pulley.
Change your belt and reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
Drive belt for planer epn 7582 n to replace a broken one
if you need a part check tool parts direct. if you have the belt, pull the side off opposite the handle that raises and lowers it. you have to roll the old belt off and then you have to roll the new one on. it will be tight and hard to do. if it isn't, there is something loose and that is not good.
Aug 31, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Masonry Tools Logo
54 people viewed this question
Top Masonry Tools Experts
Tom Chichester
ray gallant
Are you a Masonry Tool Expert? Answer questions, earn points and help others
