Question about Ge Refrigerator Evaporator Fan Motor Assembly Wr60x191
How to replace a evaporator fan motor on GE refrigerator model GBS18HBRAWW
  • 19 Answers
SOURCE: Evaporator fan not working
Ha ha
Most G.E. the fan will not work if limit control is not working, staying in open position.This also means the defrost heater will not work. If you had an amp probe it would simplify your diagnoses. you could put it into defrost,and if the amps showed heater was not coming on it would prove my theory. The limit control is a small button like switch about 1 inch in diameter cliped to the cooling
coils in back of freezer. Hope this helps.
Fxit
Posted on Feb 21, 2008
SOURCE: GE Refrigerator Eva. Fan Motor
which is the part number of the evaporator fan motor for refrigerator model GTS22KBP?
Posted on Nov 21, 2008
MNTECH
  • 1543 Answers
SOURCE: not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Posted on Dec 09, 2008
SOURCE: Need to replace evaporator fan GE profile performance TNX model
Unfortunately, the evaporator fan has probably frozen in water trapped in the defrost drain. This seems to be a common problem with these GE bottom freezer models. You can shut it off for 12-14 hours and leave the doors open and it will thaw and drain into the freezer compartment. But you probably have food that you would need to put into another refridgerator to do this. Another option is to take out the bottom liner of the refridgerator to do this - I had a service man do it the first time it happened - he then used hot water and a hair drier to get rid of the ice that was stopping the fan. Unfortunately, it seems once this problem starts happening, it will continue to reoccur and I have not found a long term solution yet
Posted on Apr 08, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I own a GE Refrigerator model#GBS18HBRAWW Bottom
if you mean the freezer froze up and you replaced the defrost thermostat in the freezer,then you need to check the continuity of the defrost heater assembly located on or under the evaporator coil for continuity(completed circuit) with at least one of the leads to it disconnected,if this shows good,then you need a new defrost timer,be it an adaptive or timer type,last but not least it could be a bad connection and this circuit could be losing power and needs to be checked,but this is very rare
Jun 06, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
My GE refrigerator is not maintaing cold temp in either frig or freezer
Probabilities:
1. Main board, most likely
2. And/or evap. fan motor less likely.
3. Defrost heater, less likely
4. Evaporator thermister, unlikely, but possible
Try defrosting it for 24 hours (by unplugging) and see if it helps.
GE refrigerator repair orange county, ca
Feb 06, 2010 | GE GSL22JFPBS Side by Side Refrigerator
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Your fan motor is bad cause you have the voltage input to your fan motor but still the motor is not operating. May be the motor winding is open, check the white and red resistance.
Mar 17, 2008 | GE GTS22KBP Top Freezer Refrigerator
Ge Refrigerator Evaporator Fan Motor Assembly Wr60x191 Logo
108 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
