Question about Zanussi ZHQ575 Electric Double Oven
My built in oven is a ZBP 1260 X and I can't work out how or where to replace the rubber supports for the plate glass door (3) after cleaning the glass. They are clanking off each other without th
The code is : 949711932. Everything else fits back in place except the rubber supports.
  • 1462 Answers
SOURCE: Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Posted on Jul 04, 2007
ginko
  • 19396 Answers
SOURCE: broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Posted on Jan 01, 2009
barkencoa
  • 3463 Answers
SOURCE: I broke the glass outside on the door of my
In my experience of repairing ovens, it is usually possible to replace glass without going to the expense of replacing whole panel.
Check with the manufacture.
Hop this helps.
Posted on Dec 05, 2009
  • 478 Answers
SOURCE: How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Posted on Feb 10, 2010
  • 18 Answers
SOURCE: will everflex heatmate glue the rubber seal to my
Everflex may work, however this is a glue specifically intended for oven door glass and rubber seals that may be more appropriate for you. There are lots of reviews on the site where people have used it for that purpose. They provide a complete kit with everything you will need to do the job.
Posted on Feb 18, 2010
How to clean between glass on whirlpool oven door
Ya gotta take the door off the stove and remove the base plate then get the glass out and clean it; a few years ago I replaced a handle on a oven door and here is how I did it:
Aug 08, 2016 | Whirlpool Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
I have just finished cleaning my oven,Creda 48107 and the plates which support the screws have slipped so the doors wont attach is this a lost cause now?
The plates have dropped inside the cabinet.
To retrieve them, you will have to remove the side panel.
There are usually between 3 and 5 screws at the rear of the oven, and the same at the front, remove these and the side panel should pull off, and you will see the plates at the bottom of the oven, fit back doors before refitting panel.
These steps are for a free standing oven, if it is built in, then you will have to remove the oven from the housing, there will probably be no side panel to remove.
Mar 24, 2010 | Creda Ovens
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Apr 21, 2009 | Ovens
How do clean behind the glass on Maytag built-in oven.
You should have a 2 piece glass in your oven. What has happened is that the seal that separates the 2 pieces has come apart or is broken thus allowing air and grease in. You can take apart the glass but it will only be temporary for about 2-3 months and will get dirty again. The bad thing about it is that te more you take it apart, the more the band that separates the 2 pieces becomes out of its form, the harder to put it back together. Unless you don't mind it, I would leave it alone or just replace it and be done with it. The question I have is, is the glass cracked or has the door been bent? Normally, the glass lasts for nearly the life of the oven.
Feb 22, 2009 | Maytag Ovens
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Zanussi ZHQ575 Electric Double Oven Logo
24 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
