Question about Fisher and Paykel DEGX1 Electric Dryer
I have a Fisher and Paykel dryer, model DEGX1, fuse keeps blowing and we lose heat. We can reset it and it will have heat for a bit, then blow again. Fan in back is clear and blowing, any ideas what would be causing this?
SolutionGuy
  • 331 Answers
SOURCE: Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Posted on Aug 23, 2007
  • 125 Answers
SOURCE: fisher paykel degx1 electric dryer
Restricted venting is the most likely cause, they did change the thermostats a couple years ago. the small t-stats should look cut out on the metal side they should not be solid, also check to make sure the elements are not shorted to ground.
Posted on Feb 23, 2008
  • 83 Answers
SOURCE: Won't heat
Not sure how old your dryer is but earlier models had the element around the door.
As a rookie you would have to remove the rear cover, the drum, the belt around the drum and then you would sse the element held in place by clips on the inside of the front panel. The thermostat would placed not too far away. I have just purchase a new dryer (very recent model) and was told the element is located away from the door. I guess I won't know until I have a problem with mine.
As usual, heed the warnings about electrical appliances and the risk of electrical shock.
Always unplug the appliance from the power point as you can still get a stock on the neutral connection even if the swith on the power point is turned off. (tunrs of the active connection only).
Posted on Sep 14, 2008
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
hunter19_46m
  • 7482 Answers
SOURCE: heatin element broken on my fisher & paykel dryer model # DEGX1
Try doing a Google search on the internet...put in your model number and make...look for parts
Posted on Sep 25, 2009
Where is the reset button for the dryer. It is blowing cool air only.
Hello
When the dryer blows only cool air, the first think that you should check is the thermostat/thermal fuse which is located inside the rear panel on the blower wheel housing. When this thermal fuse goes bad you cannot reset it and replacing this is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel DEGx1 dryer top load is only blowing cold air
Could be something simple like a limit popped due to clogged vent or a open heating element. DEGx1 Service Manual
Jul 22, 2010 | Fisher and Paykel DEIX2 Electric Dryer
Electric dryer keeps tripping reset button on bottom works for about 2 load then trips it s a fisher pakel top load dryer about 4 yrs old
main drive motor problemely has dust in start switch in the motor an the motor is staying on the start cycle an not switching to the run cycle you have to take the motor apart an clean it or you may be able to air blow the dust out
Dec 17, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Heatin element broken on my fisher & paykel dryer model # DEGX1
Sep 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel degx1 electric dryer
Feb 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
20 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
