CDDVDW TS-L633j Windows 7 cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) have tried uninstalling and rebooting, Can you h
CDDVDW TS-L633j ...Win 7... Hp Pavilion dv7-6135dx
  • 43 Answers
SOURCE: Dear Sir/Madam my laptop
-- You need to go to the Registry Editor.
-- If you have XP: Press Start then go to RUN. Type REGEDIT and press ENTER.
-- If you have Windows Vista or Win7: Press Start then type REGEDIT (it should show on the start search box) then press ENTER or left-click on the item that shows on the top left of the menu as regedit
When you have the panel up you need to make sure you follow these instructions precisely.
Click on the plus signs (+) next to the following folders to get them expanded
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* 4D36E965-E325-11CE-BFC1-08002BE10318
Once you have made sure you are on the correct folder you need to look for the "upper filter" and "lower filter" and DELETE them. It needs to be specically as it is. Do not delete it if if it says .bak at the end of the name.
After this you MUST make sure the values are exactly like this:
(Default): DVD/CD-ROM drives
Class: CDROM
ClassDesc: @%SystemRoot%\System32\StorProp.dll,-17001
EnumPropPage32: storprop.dll,DvdPropPageProvider
IconPath: %SystemRoot%\System32\imageres.dll,-30
Installer32: storprop.dll,DvdClassInstaller
-- If any of them does not match you need to double click on the item name and change the value accordingly.
Close the page and RESTART the computer.
Posted on May 20, 2011
hardkiss69
  • 43 Answers
SOURCE: UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 28, 2008
  • 76 Answers
SOURCE: Pioneer DVDRW DR-KW08HB ATA Device driver issues
To me that sounds like something got corrupted with Windows, if you have a restore CD, or know how to reinstall your OS I would recommend that, AFTER you back up your files though as you will lose anything you had saved on there. But that could fix it, or it could be the drive is bad also.
Posted on Sep 09, 2009
  • 78 Answers
SOURCE: Windows cannot start this hardware device because
you may have a problem with your software try to install windows again and if the same problem occers you may be a victum of some virues of but not sure a hardwre problem
Posted on Oct 25, 2009
  • 57 Answers
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Posted on Nov 22, 2009
Not working my cd drive.
If you are running Windows 7 you can use C Cleaner or Windows 7 Manager to clean up your registry if you don't have them you can download Regcure or Registry First Aid to clean up the reg error then you can restart your computer and see if windows can reinstall your hardware.
Oct 20, 2012 | OEM Systems Acer Aspire 5742g Dvr-td11rs...
When my Brother HL-2140 Laser printer (USB port) all of a sudden stopped printing (or prints blank pages), I went to Device Manager to check on my hardware status. Under DV/CD-ROM drives, TSSTcorp CDDVDW...
Seems like the registry for your Dvd-Rom is corrupted. Try disabling and uninstalling the driver, then enable and wait for windows to clean install its driver.
Oct 12, 2010 | Computers & Internet
My lenovo 3000c series also have this problem, code:19. please advise.... thank you
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged or corrupted.
Probably data in the registry for the device and its driver have been damaged/corrupted
Try these options,
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
or
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back or restore to the most recent successful registry configuration.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
hope this helps
please leave feedback
thanks
Robb
Apr 21, 2010 | Computers & Internet
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
TSSTcorp CDDVDW TS-L633A IDECDROMTSSTCORP_CDDVDW_TS-L633A________________AC00____&30B14D09&0&0.1.0 Failure using the VxD loader. TSSTcorp CDDVDW TS-L633A Windows cannot start this hardware...
if the usb ports are not working its down to a motherboard fault. cd/dvd roms need 12 volts and 5 volts to work if a voltage is not right it will give you code 19 to 25. have you had something short out on the usb side, i.e some device you have used in the past. usb stick tec. as sometimes it can blow a fuse on the main board, these can be replaced if you know how to solder and find the fuse that has gone.
May 14, 2017 | Acer Computers & Internet
TSST corp CDDVDW TS-L633a Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) have tried uninstalling and rebooting,...
hi there,
I guess you face aproblem in Windows Vista.
Either you try finding appropriate driver for the device for WinVista(see manufaturer's homepage, if there is none, try the WinXP one),
use exra program freeware program like 'burnatonce' or downgrade your whole system to WIN XP pro(new installation of windows after data back-up and having all teh necessary
drivers for your hardware components)
VISTA is still in trial state, ti is probably a beta version you are using...
or u wait for win7...
Good luck
Sep 13, 2009 | Computers & Internet
ASUS Nootebook M/n.F80cr.
CD/DVD Driver : 4M-TSSTcorp CDDVDW TS-L633A.
Bios V.204.
WindowsXP.Pro.pack3
My Computer not to Look on windows.
I neet driver softwere to solve this problem.
Computers & Internet Logo
1,546 people viewed this question
David Payne
David Payne
