Question about Bosch Exxcel WFX 2467 Front Load Washer
Bosch Exxcel WFX2467
We have lost our manual and our machine is flashing error message F04. Does anyone know what this means and how to solve/cure it? Many thanks for any help.
  • Anonymous Oct 14, 2008
    My error message is E05 and I have no manual either, does anyone know what this means
  • 883 Answers
Try removing power from unit and re-applying about 15 minutes later
Posted on May 23, 2007
Need to know what f04 error code is
Bosch Excel? F04 means the pump hasn't been able to pump out (or at least that it thinks it hasn't been able to pump out). There are multiple possibilities from a clogged hose, to a burnt out motor, to a bad relay or just a bad connection. None the less, I found a blog post that details how to deal with it if you're handy...
http://jgwinster.blogspot.com/2011/07/bosch-washing-machine-fault-code-f04.html
Hope that helps!
Apr 13, 2015 | Washing Machines
Stops half way though cycle with erroe message f04
Hi,There are quite a few solutions available here:http://www.fixya.com/tags/error_f04/page-5
Regards,Icom1
Apr 03, 2011 | Bosch Exxcel WFX 3267 Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Hi my washing machine bosch exxcel is not working ive checked filter the code f04 keeps flashing and i cant find my hand book to check code do you know what it means
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 03, 2009 | Washing Machines
need more info what point in the wash does it start to display the code
Sep 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
May 26, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel WFX 2467 Front Load Washer Logo
822 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
