Question about InFocus IN2104EP DLP Projector
Change fan on infocus in2104 - InFocus IN2104EP DLP Projector
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: I need to flip the image on the Infocus In2104
go into the menu, go to settings, image, and select ceiling (it's probably on "front" right now).
Posted on Mar 09, 2010
Testimonial: "Great information. Just what I needed."
How do I correct a trapezoidal display?
This is called keystoning and there should be a setting on your projector that will compensate for this problem. Usually it will be called keystone adjustment or something like this.
Jun 07, 2015 | InFocus IN2104 Projector
Fan fail in1110
You should check first the fw version. Tha last fw version is v 3.2.4. if the fw is updated it, replace de fan, if fan is ok, replace ECA controller. InFocus IN1100 Projector
Apr 01, 2014 | InFocus Corp. Open Box InFocus IN1110...
Was does high temperature error code mean?
the interior space is getting too hot.
most likely the air filters are getting blocked up.
Aug 01, 2011 | InFocus IN2104 Projector
How do you reset infocus lp 840 lamp timer?
USE THE MENU AND GO TO SETTINGS, SERVICE, RESET LAMP HOURS.
Jul 08, 2011 | InFocus IN2104 Projector
I have an Infocus IN2102EP projector. It was shutting down after several minutes of use. I contacted InFocus support and they advised to change the bulb. I've changed the bulb and reset the bulb hours. ...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 04, 2011 | InFocus In2102 Projector
How do I open the lamp cover on the InFocus IN2102EP (to replace the lamp)? Cheers
There is a single screw that you need to remove, which will allow the panel covering the lamp to be removed.
The screw is located on the back grille, opposite corner from the power connector. For a full diagram and instructions download the following PDF:
https://portal.infocus.com/support/Product%20Downloads/InFocus_IN2102%20IN2104%20IN2106_LampReplacement_en.pdf
Mar 04, 2011 | InFocus Replacement Lamp for IN2102 IN2104...
How do you use the remote for presentations? IN2102,IN2104, IN2106 Projector model.
To advance slides in a PowerPoint presentation using an optional remote control, plug the USB cable into the USB mouse connector on your computer
and the USB connector on the projector.
Jun 15, 2010 | InFocus Office Equipment & Supplies
Projector will not turn on
Is this machine newer? Is the lamp still good to go for a while or has it been burned alot the last year? If so, you might want to consider replacing the bulb. It is also a good idea to check power to the bulb socket to tell if there is a burn fuse or not. If lamp and fuse are good, then you may have a bad power supply.
Sep 03, 2009 | InFocus IN2104 Projector
InFocus IN2104EP DLP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
