Question about Epson PowerLite S5 3LCD Projector V11H252020
Epson powerlite s5 temperature sensor
After bulb replacement now temp light blinks fan runs filter is clean but no more picture
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 105 Answers
SOURCE: Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Posted on Jun 04, 2009
projdoc
  • 2237 Answers
SOURCE: Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Posted on Nov 19, 2009
stecon3248
  • 57 Answers
SOURCE: Total factory reset Projector Epson Powerlite S5
This is an anti-theft device, you will need to contact Epson if you cannot recall your password.
Posted on Aug 15, 2010
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Oct 30, 2007 | Sony VPL CS1 Multimedia Projector
What should i do when my projector's temperature light is flashing red 30 sec after start up?
try changing the light bulb. they have a time limit on them. with mine, I had to change the light bulb. Not cheap, but it worked for me.
Nov 12, 2014 | Epson PowerLite Home Cinema 8350 3LCD...
Epson powerlite 200 overheating after 20 minutes of use then shuts off.
How's the filter, if it has one - cleaned out recently? Much dust in the airways? Tried setting it into "high altitude" (or simply "high fan speed") mode and seeing if that helps?
Jan 30, 2014 | Epson POWERLITE 74C Video Projector LCD,...
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Temperature light is on with no picture
Blinking red power and temp light is an internal failure for the projector. If under warranty the whole unit will be replaced.
Jan 11, 2013 | Epson PowerLite® 83c LCD Projector
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
My Sony TV Model # KP-51WS510 flushing 4 red light or blinking 4 red light again and again, once I turn on the TV power. No picture on the screen and you will hear that it will shut off but the 4 blinking...
Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
Jan 02, 2018 | Sony KP-51WS510 51" Rear Projection...
The temperature sensor light is flashing on PowerLite Home Cinema 1080. How do I reset the temperature sensor without sending it to be reparied by an authorized Epson company.
Fist thing you need to do is check all the filters.
Take them out and use a vacuum cleaner on a gentle **** to clean out the dust.
Use the brush attachment also go around the projector and de dust all the grills.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Epson PowerLite Home Cinema 1080 Projector
A light is blinking red "TEMP"
Open the bulb replacement door, pull out the filter and spray it with dust off. (compressed air) Check the fan, clean it out as well. Should be fine after that. if you need further help, post a comment and i will help some more.
Sep 30, 2010 | Panasonic PT L6510U Multimedia Projector
Epson PowerLite S5 3LCD Projector V11H252020 Logo
138 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
