Question about Kenmore Dryers
Fuse was out in dryer, put in new fuse, still not heating up
Wondering if the wiring is done properly
    Problem Solver:
  • 4 Answers
Check the heating element
Posted on Jan 03, 2009
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
Hoover Clothes Dryer Apollo 100 D6176
Most electric dryer problems not heating are due to the heater coil circuit being broken. The wiring can be replaced by the coil kit being purchased from an appliance parts store. Need make and model numbers. Follow directions in package.
Oct 13, 2013 | Dryers
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
Have put in new heating element and new thermostat still no heat I am wondering if there are any fuses that maybe blown
Could just be a tripped or faulty limit switch. They are about the size of a quarter, are close to the element, and usually have two wires to them. You can temporarily wire around them to see if they are faulty but be careful you are dealing with high voltage. Unplug before trying anything. Some of these limit switches have buttons right on the top you just have to push to reset.
Apr 12, 2011 | Whirlpool Dryers
Electric dryer will not heat up is there a reset button
Their is no reset button. On the back side of the basic dryer they have the filter and blower housing with temp control klixon and fuse and on the right hand side is the heater with a pair of limits on it which trip if the temp exceeds safe levels due to air restriction. themobilian_565.jpgthemobilian_566.jpgthemobilian_567.jpg
The newest wonders look a lot like this inside.
I have a service manual and more HERE
And HERE
Dec 26, 2010 | Kenmore Dryers
I have a model MDG308DAWW gas dryer which is experiancing No heat issues. the burner will fire up occasionally when we first load it and then will not come on for the rest of the dry cycle, I have cleaned...
Hello there:
If your dryer doesn't heat, check these:
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Sep 01, 2010 | Maytag MDG308DAWW Gas Dryer
Electric dryer model # 110.68422700 type:dwjr-ele-2406028-fm54. Heater not working. I am an electrician so when i get my meter I will check points. Just sort of wondering what to check and where? Also just...
take the back off the heating element will be on the right side as you face the back of the dryer inside a metal container. The heating element is resistor wire. The other part that commonly goes bad is a thermal fuse it will be connected to the heating element but mounted on the back of the dryer near the bottom center right. The fuse should show continuity so should the heating element. Elements sometimes ck good but if you shake them the wire will seperate.
Aug 10, 2010 | Kenmore Dryers
My dryer does not get hot any longer, it is like lukewarm, when checked the hose in the back was torn, we replaced that and we had the same problem. Now I purchased a new dryer and the same problem...not...
1) did you check to see if the flappers outside actually open to alow the proper flow of air
1) did u check the two 30 amp fuses in your house to make sure they are ok
3)has there been any work done to your house wireing like a new box put in the wall if so have qualified repair person check for proper wireing
it sounds to me like the wireing has beenchanged some where
or the plug u are plugging the dryer into is defective
(solve ya prob)
Oct 18, 2009 | GE Profile Prodigy DPSR513GA Dryer
New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
May 29, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
