How do you print envelopes on a Bizhub 222?
SOURCE: printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
SOURCE: How do I get our Bizhub 350 to print on envelopes
Create your document at the appropriate size, #10 Env.
On the device, set the BYPASS tray to a size setting of the same. Look under the custome sizes as there may already be one there.
There is a switch just inside the device, near the bypass tray where you set it for envelopes. this opens up the feed gap to allow for the thicker envelopes.
this is all contained in the manual.
SOURCE: Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets
Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
SOURCE: how do I print labels on the bizhub 222
Be sure to load label sheets so that the side to be printed on faces down and a maximum of 50 label sheets can be loaded into the bypass tray.
USER MANUAL page 2-64
http://kmbs.konicaminolta.us/productsattachments/manuals/bizhub362SeriesCopyOperationUserManual.pdf
