Question about Nintendo DS Console
My ds charger plug is bent
My ds was working fine until i put in a different charger in the nintendo ds. later I when my ds died i went to charge it and realized that that were u plug in the charger was bent is it possible to fix it .
  • 41 Answers
The only concern is if the connectors inside the charging station is corrupted. The bending is simply the outer metal connection, then bending it back wouldn't cause any damage. If the problem is further inside the station, it needs to be replaced. Nintendo can replace it for you for an acceptable price.
Posted on Jan 04, 2009
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
NINTENDO DS LITE,CHARGING LIGHT
I would suggest to double check your flex wire connections and make they are connected properly.
Apr 11, 2008 | Nintendo DS Lite Console
My Nintendo DS quit playing sound through the speakers. It only has sound through headphones. One minute it was working then the battery went dead. After I plugged it to the charger the sound does not...
Try leaving the DS on until the battery dies, then charge it all of the way with the DS off. If that doesn't work, I would call Nintendo customer service. They are excellent at helping people with problems just like this. Here is the 800 number I got off of their website. 1-800-895-1672
May 03, 2011 | Nintendo DS Lite Console
My hubby bought me a nintendo ds and a couple of games about 2 years ago, all worked fine, i put it away and didnt play with it for ages, started playing with it again recently it works fine with my...
have you tried updating the firmware on the DS? It maybe because of that , that it wont play newer games? You will need to connect the DS via wifi to your home network the same way your laptop etc connects to it and then go into the DS settings menu and choose system update. Make sure the DS is fully charged and connected to a mains charger BEFORE updating. See if that solves your problem for you
Mar 20, 2011 | Nintendo DS Console
My son has a DS lite. It was working fine and now
possibly fuses have blown on the logic board, but it sounds like it needs a new one board.
Jan 07, 2010 | Nintendo DS Lite
Nintendo DS Lite won't charge
It is your DS somehow it is messing up the battery try the battery on atnohter DS
Nov 10, 2009 | Nintendo DS Lite
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Power gone on nintendo ds lite
Hey if you have a warranty nintendo might repair or raplace the Ds.I thought about replacing the charger or place the charger in another power outlet.I hope I helped.
Dec 30, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
298 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
