Question about ASUS K55vd-db51 16" Led Notebook - Intel Core I5 I5-3210m 2.50 Ghz - M
Battery does not charge in new Asus K55VD laptop
The adaptor powers the computer but the battery will not accept a charge.
I have same probliem in my laptop Asus K55VD if i put a charger it get on other ways a massege showing that Battery is not avilable.
i think its could'nt help battery is ok i buy it yesterday and its genuine new i don't know whats happend can someone else help me
Posted on Nov 15, 2012
  • kr_kingkhan
    kr_kingkhan Nov 15, 2012
    i have same probliem in my laptop Asus K55VD if i put a charger it get on other ways a massege showing that Battery is not avilable.
SOURCE: My ASUS Eee 1000HE netbook
it could be the pin on the inside of the machine. The jack is tiny and the pin may not be connecting to the proper wires any longer. I had a similar problem with a compaq laptop..it had to be soldered for a temporary fix, the netbook itself has to be taken in. It's the only flaw I see with these machines.
Posted on Feb 11, 2011
Damilare
  • 358 Answers
SOURCE: laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Posted on Jul 10, 2009
Joed911
  • 4338 Answers
SOURCE: charging my asus 701 laptop
Usually what happens is that the ac connector on the laptop get loose. It happens when you wiggle the ac adapter out rather than pulling it/pushing it straight in. You can check if this is the problemsby
powering off the laptop. Insert the ac adapter. just slightly wiglle it. if it wiggles at all, then this is the problem. It can be fixed by resoldering the connector back on the System board, which entails taking the laptop completely apart.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
haayz
  • 197 Answers
SOURCE: i have a dell 1545 and when it is plugged in the
try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
if it doesn't work i suspected that there's a problem with the power socket from your machine. you can check it with the nearest service center near you.
Posted on Jul 03, 2009
  • 20 Answers
SOURCE: My ASUS Eee PC Battery Indicator's going weird
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena11
Posted on Jan 03, 2010
Where to find cmos battery ? asus k55vd
you will have to open it up first then you will find the battery on the board.
May 03, 2014 | ASUS Computers & Internet
Laptop giving error
Hi, i think, i can help you in that case, just hit me on 18443555111 (toll-free) whenever you have time.
Sep 22, 2017 | Dell Inspiron Computers & Internet
My battery do not keep any charge, but its condition was diagnosticated as "excellent" with specialized programs. The laptop works only with an automatic multi adaptor (Woxter brand). The system reports...
"plugged in, not charging" could a symptom of incompatibility between the charger and the battery.
If this is the case, once you unplug your ASUS ac adapter, the laptop goes off.
Anyway, it's still Ok to use the charger but you need to plug it in all the time.
Here is a little trick that I found that works.
1. Power up the Notebook with the battery installed,if you can.
2. Turn the computer completely off and remove the battery.
3. Power up the Notebook with AC power only (no battery installed).
4. Turn the computer completely off and re-install the battery.
5. Power up the Notebook.
6. The message no longer appears (at least for me it has disappeared).
Aug 12, 2013 | ASUS Eee PC T101MT-EU27-BK Convertible...
MSI Wind u100 - battery LED flashing red
check for an update with windows 7 then go online to asus support or call them. They should have a solution for you.
May 12, 2010 | MSI Wind U100-053US 10-Inch Mini Laptop
THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER UP WITH THE CORD OR BATTERY DEAD. IS IT THE BATTERY OR CORD THE PROBLEM. MY OTHER LAPTPS WILL STILL POWER UP IF THE BAT IS DEAD, IS THIS NOT TRUE FOR THE...
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Dec 31, 2009 | ASUS R1E-B1 Tablet PC
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
Power supply issues, wont charge.
Dear,
This is isse with your power adaptor. Its not having the capacity to light up the scree while working. But it is having the capacity to charge you battery. You have to replace your power adaptor
Oct 13, 2009 | Toshiba Satellite P205D-S7479 Notebook
BATTERY PROBLEMS?
Hi
Latitude D620 battery module has a battery charge tester. First remove the battery or turn the laptop over and press the battery icon and the note the battery LED indication.
If there is no LEDs lite, shut down the laptop, connected the power Adaptor, install the battery and check if the battery charge LED lites up.
If it doesn't double check the power Adaptor. Latitude D620 is rated to use a 90W Adaptor. There is a 60W Adaptor (looks very similar to) but this is for other Latitudes and AMD Vostro systems.
If the Adaptor has the correct rating, then check below for more info;
1) [Very Likely] The battery may be faulty or end-of-life and needs replacing. Check the battery connector on the Latitude and battery itself for any broken or bent pins or bits.
2) [Possible] You have the wrong power Adaptor or the Adaptor is faulty. This however would not explain why the battery is undetected.
Start up the Latitude into System BIOS (F2). Under System > Battery information check the battery and AC Adaptor status
If the Latitude D620 has warranty you may open a warranty claim with Dell Support.
Mike
Apr 02, 2008 | Dell Latitude D620 Notebook
ASUS K55vd-db51 16" Led Notebook - Intel Core I5 I5-3210m 2.50 Ghz - M Logo
1,717 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
