Printer works fine, but the HP solution Center always shows - No HP Devices Detected, and says it will close now.
It all worked fine and then all of a sudden, this error message starting showing up and I don't know how to fix it, so I can scan and copy to HP laptop
Comments:
Jan 03, 2009
- HP Laptop gives the No HP Devices error message.
Printer screen reads " No scan options, refer to device documentation to troubleshoot."
I wanted to clarify my printer/scanner problem.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
when printing from computer, printer starts and them pauses for about 1.5-2 min. then finishes the...
(More)
when printing from computer, printer starts and them pauses for about 1.5-2 min. then finishes the print.
I have taken the trays out of printer, which has caused the gears to be out of timing. (I'm an ECR...
(More)
I have taken the trays out of printer, which has caused the gears to be out of timing. (I'm an ECR tech. by trade) Does anyone have any timing diagrams for this machine? Bob
