Question about Motorola Mobility RAZR V3
Motorzor Hi! My phone won´t turn on, I thought I had just drained the battery but when I plugged it in to charge, the screen display said it is charging and that the battery was full but the phone still didn´t turn on. The screen is fine when it´s charging because it does display information, the phone just won´t turn on.
    New Friend:
I NEED MY PHONE TO TURN ON. IT POWERS UP AND SHOWS THERE IS NO BATTERY CHARGE AND KEEPS BLINKING "SAMSUNG", BUT WON'T GO ANY FURTHER THAN THAT. I PUT THE BATTERY IN ANOTHER PHONE THINKING I FRIED THE BATTERY, BUT IT WORKS FINE AND I WAS ABLE TO TURN AN OLDER PHONE ON TO USE UNTIL I FIGURE THIS PHONE OUT.
Posted on Dec 11, 2013
    Scholar:
  • 91 Answers
You simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
Posted on May 13, 2007
  • coonkid20705
    coonkid20705 Dec 27, 2012
    Thanks, Matt! Please explain process and what's needed (ie: charger) expressed in your second sentence.
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
I phone wont turn on
This will happen when the battery has become completely drained. Plug it into the wall using the A/C adapter and allow it to charge for a while. If it still won't power on, hold the sleep button (on top of the phone) and the home button for about 5-6 seconds for a soft reset. When you plug it in you should see the symbol of a drained battery on the screen as it charges up.
Nov 23, 2011 | Apple Cell Phones
My HTC keeps freezing and then shuts off and it won't turn .. I have to plug it in my charger and I'm about five minutes it turns on
I would delete any live widgits off your desktops such as facebook or myspace etc. It constantly drains the battery and working with phones I have had it actually drain the battery faster than it can charge. If the charge is not the problem I would, while the phone is turned on, remove the battery...this is a soft reset and can fix most issues with freezing.
Aug 26, 2011 | HTC Inspire 4G Smartphone
The battery drains far too quickly on my Samsung G600 (have tried new batteries but same problem). Any idea what is causing the power drain?
In many instances, some phones run a lot of applications in the background unfortunately, in most cases of a fast battery drain, it is due to high screen brightness or a long screen time-out. Try turning down your screen brightness to a lower setting (one which you can still see without straining) and check to see how long your screen turns off. Some phones default to 30 secs or 1 minute. Use a lower setting if possible.
Also, cell phone batteries are lithium batteries. At first use and then on a periodic basis, try draining the battery until the phone will no longer turn on and only then plug your charger in. If you plug the charger in before it is dead the battery will not be used to its fullest capacity. Hope this helps!
Feb 28, 2011 | Samsung SGH-G600 Cellular Phone
Phone was dead says battery charged...power off why wont it work
If the phone charges the battery as it is displayed on the screen when a charger is plugged in but does not power on, the power button/switch is faulty. Have it checked and replaced by a qualified technician.
If the phone doesn't charge the battery, the battery is probably drained or dead. To verify, grab a voltmeter and check the battery voltage. Set the selector knob to 10V DC. Voltage reading of less than 3 volts indicates the battery is drained or dead. Use a known good battery.
If the battery is good but the phone still does not turn on, it is dead and have it checked by a qualified technician.
Nov 26, 2009 | LG RUMOR Cellular Phone
Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
May 22, 2009 | Motorola Mobility MOTORAZR maxx V6...
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Screen shows battery with a red line through it
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Help! thought battery was dead but...
try a master reset and clear all data on the phone......if that does not work have the phone's firmware reflash by taking it to a professional mobile store and getting it done there.
that should fixed you issues with the phone :)
Jan 09, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
741 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
