Arrow T59P It will not push $591189 clear staples into wood. It misses the metal staple and hits the edge of the plastic insulator instead. I have to pull out the broken pieces and for every 20 staples, I will get one to strike the staple and not the plastic.
SOURCE: HP Officejet 7410 All-In-One Printer
This has nothing to do with the cartridge you used. Its a pure and simple design fault from HP that has exsisted since the 7210, 7310 and now the 7410. I am working with the European consumer commission and the UFC in France to get a resolution for European customers. US customers can get a replacement it seems by mentioning this thread ...
http://www.fixyourownprinter.com/forums/...
If anyone else is living in Europe please contact me. Its not fair that US customers have there printer replaced and Europeans must pay to "upgrade" there printer.
Posted on Dec 07, 2007
Kevin Hayes
  • 167 Answers
SOURCE: LOADING STAPLES
http://help.bt.konicaminolta.ca
go here to get that Manual, it is good to have anyway
Posted on Sep 10, 2008
sbg_ofp
  • 10 Answers
SOURCE: Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Posted on Nov 05, 2008
mikeymiddles
  • 58 Answers
SOURCE: piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Posted on Jan 11, 2009
SOURCE: WHERE ARE THE STAPLES?
to  the left you will have a narrower section  and it will possibly have mail box attachment and job divider shelves that ride up and down .......this is the finisher unit
separate this section from the main body of the machine
beware of the paper reciever falling as you separate  take hold and lower
when you have separated  remove the bridging paper reciever OR hold up
staples are inserted in the unit central and to the right of a green rolling wheel
grasp the green bar on this unit and pull upwards   your staple bars go into this piece that should be in your hand
Posted on Feb 23, 2009
Replacing staples
On the back there is a small metal piece that is spring loaded push it in and down and that should release it pull it out and slide staples in replace assembly remembering to push in and up to reinstall holder .Hope this helps.
Bob
Jul 18, 2014 | Arrow Fastener T72 Wire & Cable Staple Gun
T59 arrow stapler doesnt set staples all the way into wood
Is this just on one piece of wood or does it act that way on all kinds of wood? Some wood is denser that others and that would cause the staple to not go completely into the wood.
Jan 13, 2014 | Arrow T59 Cable Stapler For Insulated...
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
How do you load new staples?
Find the button on the bottom of the stapler's back edge. Push the button in and down. Pull out the bar that pushes the staples into place. Slide in a row of staples with the points facing down. Push the bar back and lock it into place
Feb 20, 2011 | Arrow CHROME STAPLE GUN ARROW IND....
I would like to know where I can buy staples 804-809 for my Swingline Professional Saple Gun No. 10011
Hi,you can use any brand staples on your tool..
As an example here is a link on ebay for 5/16 staples..
Take care and please remember to rate me..Regards
Arrow 591188 300 Box 1/4"x5/16" Clear Insulated Stapleshttp://cgi.ebay.com/Arrow-591188-300-Box-1-4-x5-16-Clear-Insulated-Staples-/130360323235?pt=LH_DefaultDomain_0&hash=item1e5a14aca3
Nov 05, 2010 | Staples Swingline® 36115 Staple Guns Tools...
The stapler is fixing two staples instead of one at a time.what can be the defect and how to correct it?
First check and make sure the proper staples are in the gun. Also check and make sure the stapler is clear and no jammed or broken staples are in the gun. If this is a desk stapler make sure the plate is locked in for the staple to hit and bend the ends out or in. if all this is working the driver or the piece of metal that pushes the staple out may be bent. If the stapler is new take it back if it is not a minor problem and get a new one.
Jul 01, 2010 | Tools & Hardware - Others
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
The staples do not enter the wood completly
often when squeezing the tool the front gets lifted and the staple does not set fully. try making sure the front is tipped down fully and in contact wood when it fires. if that doesnt work the push rod is not working properly and is easier to replace than try to fix
Apr 22, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
jasbo
jasbo
