Question about Jenn-Air JCD2295HES Side by Side Refrigerator
No cold air n at all in refridgerator or freezer oadmirall sideo
Redridgerator is an old admiral side by side selling house cant buy one refidgeraor freezer fan turning no cold air belt in back is moving on refridgerator back no col air cleaned bottom i see no freezer fost aloud noise by fan in freezer can you tell me whats wrong
  • Anonymous Mar 28, 2014
    Freezer is warmer then usual
    Problem Solver:
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Posted on Jan 03, 2009
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have an admiral refrigarator but it doesnt get cold both sides
Sounds like a bad freezer fan motor .(in the freezer section)
Aug 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Our refridgerator is not cooling well.
These units only have coils on the freezer side and just blow cold air to the other side through small ducts. These ducts have a tendency to ice up and block the airflow. Do a manual defrost for about two (2) hours and then plug it back in. Hope this helps. Good luck.
Jun 05, 2009 | Admiral Refrigerators
Help refridgerator has no cold air
If fan under freezer is not running and or the compressor? That will be clue to helping you resolve this. Let me know.
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Trubleshoot refrigerator staying cold enough
First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
122 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
