Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Centrifugal switch failed to close
Coleman evcon #980653645
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
  • 70 Answers
SOURCE: i have a coleman/evcon electric
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
farfield
  • 462 Answers
SOURCE: i have a coleman evcon dagto7obdd fan keeps
Check for continuity through all your switches. Check voltage where these switches hook up to your control ignition box.if you see voltage there the problem is either the wiring or one of your switches is open. If you read no voltage there check again from "C" to the same wires a readign then indicates a bad board. Then check "R" to there a reading here indicates a bad thermostat (which is probably not your trouble due to the code and your legend of the code 4)
Hope this is cleaR and helps Please grade am accordingly and good luck.
Posted on Mar 11, 2009
  • 3313 Answers
SOURCE: coleman furnace(propane) will not start
change presure switch , no quick fix
Posted on Sep 17, 2010
  • 77 Answers
SOURCE: coleman combustion air switch failed
If the vacuum switch did not pull in first look to make sure there are no restrictions in the vent pipe if the vent pipe is real long try disconnecting it from the furnace then try to run the furnace again. If that's not it take the rubber hose loose from the combustion blower and **** on it see if the switch itself is bad. If the vent is cleaned out and the vacuum switch sucks in with little effort then your combustion blower in not pulling the proper CFM (cubic feet per minute) and needs to be replaced.
Posted on Nov 24, 2010
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace is noisy loud
To many possible answers to this. A description of the noise will help to diagnose the problem.
Jan 28, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
I had a coleman evcon installed in 1997. model no.BPCH0241BA serial no.960384813.How do i get new instruction info? I cannot find mine. thanks deb
If you go to the top of a fixya page they have a search bar just search for coleman evcon instruction manual and you will get some help from one of fixyas experts.
Aug 20, 2009 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Evcon coleman furnace
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Jan 23, 2009 | Tools & Hardware - Others
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
