Question about Stihl Concrete Cutoff Saw Carburetor Ts 700 800 Hs
Stihl ts 700 low rpms - Stihl Concrete Cutoff Saw Carburetor Ts 700 800 Hs
2 Suggested Answers
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
Saw runs for awhile then shuts off and continues to run.
i always have to start the saw and then pull the trigger like every 5 seconds for about a minute then it works for me
Sep 18, 2013 | Stihl Concrete Cutoff Saw Carburetor Ts...
First my Stihl Quikcut was getting too much gas now after rebuilding the carb it's not getting enough
Not sure who told you about the compression but that is not true, are you sure the throttle rod is actually pushing the throttle shaft open?
Mar 17, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl 410 wont start put new spark plug but no spark
Try a new coil.Hope this helps and Thank You for asking!!!
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
My stihl demo saw ran out of gas an i filled it back up with the proper mixture an now it wont start
Remove plug and clean/replace. also check in the tank for a filter on the end of the fuel line.
Ground the plug of the body of the saw and stry to start to see if you are getting a nice healty spark. If you tank ran dry then you may have contaminated your plug.
Jun 20, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Hi there; my stihl ts 420 does not start easily
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Running bad with oil leaking out the muffler crimps. Too much oil in the mix? Cleaned the air filters already and checked the spark plug. Looks good, maybe the carb?
Check the spark arrestor screen and see if the screen has carbon deposits on it. If it does then you need to clean the spark arrestor screen and re install it in the muffler. You can clean it by burning off the carbon. The air filters on the TS 700 Cut Off Saw do not need to be cleaned, they only need to be replaced when the unit starts running poorly. The carburetor could have something in it that is keeping the needle from closing and flooding out the unit. I would suggest taking this unit to a Stihl dealer that has a Gold Certified Technician. You can use the dealer locator on the the Stihl USA website. I have included a link HERE. You can type in your zip code and it will tell you where the closest dealer is and what level of technician they have.
May 14, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
STIHL TS 400 won't start
I just repaired one with a similar problem--not getting enough gas. Two things corrected it and both were carb related. First I replaced a rather stiff diaphragm with a new one and second I reset the intake valve to allow more fuel into the carb. That solved it. Good luck.
The gas filter is weighted and should remain at the low point in the tank so it is an issue only when you are about to run out of gas--unless gas has been sitting in the tank for a long time. That can leave a film on the filter that can restrict fuel flow. Pull the fuel filter from the tank and scrap lightly on the filter. You will immediately note if there is a film on it. If so, replace the fuel filter.
Mar 15, 2009 | Hand Tools
Stihl Concrete Cutoff Saw Carburetor Ts 700 800 Hs Logo
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
