Since I changed the black cartridge and messed about with print head alignment I can hardly get any print at all (although these could be coincidental to the print failure).
The faintest lines of what seem to be random colours is all I can get - whatever I try to print. I've tried everything but now I've run out of ideas. Any suggestions?
An expert that got 10 achievements.
An expert that got 5 achievements.
An expert whose answer got voted for 100 times.
Epson Master
Re: hardly any print
Check out my previous solutions on completing the under head cleaning routine. It's soemwhat safer than the syringe on the wick method and is not likely to break the piezo actuator on the head.
Previous post: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
You can also look at this post about loss of ink as it is relevant to your model:
http://www.fixya.com/support/t136779-cx6600_prints_blank_sheets
Let us know how you get on
Genius:
Master
Download this utility -www.ssclg.com
set your ptinter model and right click the icon in the taskbar.
Take a look through www.fixyourownprinter.com
This useful tool that you can make will be a boon for blocked jets
Hi, the print head needs to be removed and washed with warm water, Please check the manual for print head removal and re-installation. Also print head alignment must be done on re-installation. The process sounds complicating but is quite simple. Do as if you are replacing a ink cartridge. When the print head is at centre in this process and stops.Switch power off on printer.Remove the cartridges, then remove the print head, wash in warm water carefully, do not use any brush or do hard rubbing, dab dry on paper towel. Replace print head into printer, then cartridges, then switch power on. Do print head alignment, clean print head once and print test pattern. Hope this helps as it has worked for me and is still working. All the best.
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
sounds like you replaced the black cartridge, do you run the "align print head" on the printer. Sounds like the black is not aligned to the printer input.
Make sure all the protective tape on the Black cartridge has been removed. Also are the inks re-filled? I have seen many re-filled cartridges fail in a similar maner.
if the cartridge is not flowing...I would NOT soak it in water as that can flow back into the cartridge...remove it and use a q-tip with rubbing alcohol to clean...then you can use toilet paper to rub across it to make sure its flowing...you should get a solid black line...be sure not to touch where the electronics connect to it...if you do, clean it with the alcohol also
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
I've seen this happen with clogged heads as well. If even one color of the color cartridge does not print, it will mess up the alignment page. I'd say take a damp paper towel, wipe the print head off. That the area on the cartridge where ink comes out. after wiping, do a "foot print" test. Gently but firmly, lol press the print head into the damp paper towel. You should see a blue yellow and red foot print. They should be about the size of the print head itself. Do this for the black as well. IF you don't see good foot prints, then take them to your local cartridge world and get them replaced!
