Question about LG WM2455 Front Load Washer
LG WM2455HG ERROR OE AND WONT SPIN - LG WM2455 Front Load Washer
stradeteox
  • 88 Answers
SOURCE: When I try to run the TUB CLEAN feature on my LG WM2455HG, it err
Actually, that is not an error code. It is telling you to add bleach to the dispenser for the tub clean feature.
All you need to do is add bleach at this point (or Whirlout which works even better). Make sure you do not have any clothes in the machine when doing the tub clean cycle.
Hope this helps, please rate my answer.
Posted on Jan 11, 2009
buffalonyman
  • 1865 Answers
SOURCE: MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Posted on May 06, 2009
SOURCE: LG WG3431HW OE Error: Rattling & Not Draining.
water will not drain says oe
Posted on Aug 08, 2009
rdrsp
  • 85 Answers
SOURCE: lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Posted on Oct 26, 2009
SOURCE: LG TROMM wm2075cw gives an error of OE...
Washer has a filter, at the bottom left handside of washer, which needs to be cleaned out. Refer to manual. Worked for me :)
Posted on Dec 04, 2009
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
Dryer does not spin dry, water left in drum...Error code OE
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 02, 2011 | LG Dryers
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
LG WM2455 Front Load Washer Logo
233 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
