Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My WD Mybook Home edition is not recognized on my computer and the front light keeps flashing
  • jollymoon May 06, 2009
    How about won't detect in Win7?
    USB drivers are supposed to load the WD MyNoteBook 250G Essential, but I can't even use the diagnostic tool you mentioned above and Win7 balks at trying to load drivers or troubleshooting.
    Any ideas
    thanx!
  • 728 Answers
Hi bosco3rd401,
First Go to this link. Where they will explain the differences of the meanings of the flashing lights. There are so many variables, that it would be to difficult to figure out unless I was actually working on the disk itself. But the page is very easy to understand, and hopefully you'll find what I did, was all I need to do was to power down and up again.
Then, if that doesn't solve the problem, then you have to determine if the drive is working or not.
Either the drive itself failed or you did not stop your external hard drive safely in your PC or Macintosh before unplugging either the power or data cable.
1: Determine if the drive itself has failed
For purposes of testing, connect the power adapter directly to the wall. If you do not hear or feel the drive spin up when you connect the power, the drive will need to be replaced. If the drive spins up, but nothing shows up in My Computer or in Disk Management, change the USB cable and connect the new one to another port on your Computer. If it still doesn't show up in Disk Management, try the drive on another PC to see if it shows up on that computer. If that computer still does not detect the drive by showing you the system tray icon or by listing the drive in the Device Manager after you plug in the drive, the drive is bad and needs to be replaced.
If you require data recovery services on your failed drive, here's a list of authorized preferred data recovery partners
If you find that you do need to replace your drive, here's a link to WD to replace it.How can I replace a product under warranty?
2: Determine if the drive can be used again
If the computer does detect the drive, you can test the drive by using WD's Windows Data Lifeguard Diagnostics. For more information on how to use the software to test the drive, Click here: How to test a drive for problems using Windows Data Lifeguard Diagnostics
Now If the software reports an error for the drive, you will need to look up what it means here: Data Lifeguard Tools 11 Error Codes .
If the software shows no errors for the drive, and you do not wish to send the drive for data recovery, you can partition and format the drive so you can use it again. For step by step information on how to format the drive click below:
How to partition and format your hard drive (from unused space) for use in Windows XP or Server 2003
IMPORTANT: To avoid corrupting or losing the data on your external hard drive you should always shut down the drive correctly before you disconnect the data cable from the drive or computer, or the power connection from the drive or the wall outlet.
I hope this helps and Good Luck!
Mark
Posted on Jan 04, 2009
Change mybook from one pc to another
You have to install the backup software on the new computer. Either download from WD to use what came with the MyBook. Attach the MyBook and find it in My Computer. If it is not there, you have to reboot and find the attached device. After Windows recognized the drive, the backup software will ask you for a new backup but just decline and reactivate the plan (actions/reactivate). That should do it!
Dec 05, 2011 | Western Digital My Book Essential Edition...
Mybook WD25001032-001 keeps on flashing and won't work...what is wrong with it. I need help. Thanks
Try plugging the usb cable on a different port on the computer. If the light flashing is red, then there is a hardware problem on your WD. If this is still under warranty, then its best to have it checked from where you bought it or to any authorized WD service center. If its no longer under warranty, then you can open the WD and check for any disconnection. The inside contains a harddisk; you may want to disconnect the two connectors from the harddisk and reconnect them again.
Mar 25, 2011 | Western Digital 250GB MyBook External USB...
Notebook does not recognize My Book / Western Digital hard drive
Did it ever work?
Connect the MyBook to a different desktop computer.
If it is not recognized, then the MyBook definitely has a problem.
Exercise the warranty to get it repaired/replaced,
or check W.D.'s "Customer Loyalty" program -- buy a new W.D. drive through W.D.'s web-site, and get a discount.
Nov 01, 2010 | Western Digital My Book Essential Edition...
Connected but not detected?
Hi, You need to run updates for your computer. Go to start, program, windows update, run and install all the updates, look especially for any update for hardware, select it and let it install. Leave the My book attached to the computer while searching for updates. Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
Western Digital MYBOOK 500GB external harddrive won't come on. When it plugs in, the blue light comes on for about a second. Computer does not recognize drive.
It is "dead". If it is still under warranty (check 'www.wdc.com' for details), then Western Digital will replace it. If not, check their web-site, for their "Customer Loyalty Program", i.e., since you bought one W.D. disk-drive, you can get a discount on buying another W.D. disk-drive, if you order online from W.D.'s web-site.
Dec 11, 2009 | Western Digital My Book Essential Edition...
Computer doesn't recognize WD MyBook 500GB but no error message
Try using the western digital knowledge base info to help you resolve the problem...click here.
Otherwise, we need the full model # and the OS you're using to give better solutions....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
823 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
