Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
Can't pick up wireless internet through router
I am trying to pick up the wireless internet from my modem upstairs so that i can play my Xbox 360 on Xbox Live but when i test my connection it fails to find the DSN. Any help?
  • pb658482 Jan 06, 2009
    yea figures thats so beat....you pay 250 for the system then gotta pay an extra 150 for the membership and internet just to play online......********
You need to have the specific wireless adapter made for the Xbox 360. It runs about $100. Other wireless adapters (for some reason) will not work. I tried 6 different ones before I gave up and hard wired the Xbox 360.
Posted on Jan 03, 2009
Can't connect XBOX 360 S to D-Link DIR-600 Router
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Mar 04, 2012 | D-Link DIR-600 Router
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :)
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox360
Hello taz1028,
In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
Sincerely,
Agent Xiong
May 31, 2008 | Microsoft Xbox 360 Elite Console
Ho wdo we get connected
You will need a high speed internet connection, a modem, a router, and a wireless networking adapter. (microsoft brand).
For installation, please contact me so i can guide you.
May 11, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
201 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
