Question about Panasonic Technics SL-DZ1200 Turntable
How do I change belt on a Technics linear SL -H350 turntable
I am unable to remove the turntable to replace the belt on my Panasonic/Technics SL-H350 deck.
How do I do this?
The turntable does not lift off like normal decks.
  • ajslaton Jan 29, 2009
    I have a Panasonic SG-V55 turntable with a broken belt, and I can't figure how to remove the turntable deck. It is held down by a metal ring in the middle of the deck.
  • 104 Answers
Http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Posted on Feb 11, 2009
Technics SL-1210M5G Turntable
1 If it's a belt turntable - the belt slips off.
2 A power supply problem.
3 A faulty motor.
Jun 27, 2012 | Technics SL-1210M5G Turntable
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
How do i install a belt on technics turntable sl-bd22
If you remove the rubber pad, you should be able to grasp the metal table. A gentle tap onto the center spindle while pulling up on the table should release the table. Place the new belt onto the underside of the table. Replace the table onto the spindle. Then feed the belt over the motor hub.
Dan
Apr 20, 2011 | Technics SL-BD22 Turntable
Technics SL-B205 turntable runs too slow
I have a Techniques SL-23--just bought two brand new belts. One runs too slow and the other too fast.
How do I fix it?
Feb 24, 2010 | Technics Audio Players & Recorders
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
Oct 28, 2009 | Technics SL-1210 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
LP Turntable
the platter must be able to spin freely without a belt installed as shown in this video
http://www.archive.org/details/Turntable_Belt_Installation
that would be one likely cause presuming you have the correct new belt that is.
Oct 26, 2008 | Panasonic Technics SL-DZ1200 Turntable
Problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 22, 2008 | Panasonic Audio Players & Recorders
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Panasonic Technics SL-DZ1200 Turntable Logo
940 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
