Question about LG WFT1071TP Top Load Washer
Lg wf-cl700 top loader manual - LG WFT1071TP Top Load Washer
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Posted on Nov 23, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
  • 3230 Answers
SOURCE: I am getting error DE
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Posted on Dec 03, 2010
What is the load capacity for the WF-T7014 PP Top Loader please
It's always a good idea to check the manufacturer's website. If you can't find the specific answer from LG website, just click on Support - call, chat or email available.
LG Electronics Consumer Electronics Appliances from LG LG USA
Jan 08, 2017 | Washing Machines
When I Fill my washing machine (Top loader Lg Wf-T7015tp), it Makes a Funny Noise and die when I start the program.Is it the Capasitor or is it the v-belt tension?
If the noise is only when this function of filling, and if you are only using one of the two fill valves, may be due to the magnets of the inlet valves of the water, which are activated in filling and are disabled when you start the program. that noise is normal unless it is very strong and is the preamble to the damage of the two valves.
Nov 10, 2014 | LG Washing Machines
Where can you find the presure switch lg wf- t1233TP
where can I find a display board for my lg wf-t1233tp top loader washing machine
Jul 04, 2012 | LG WFT1071TP Top Load Washer
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
200 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
