Question about Vehicle Parts & Accessories
How do I get out of valet mode with remote nahrled4?
I have a five-button remote start and I think I'm in valet mode. How do I get out of that? Thanks.
3 Suggested Answers
MECP Guy
  • 344 Answers
SOURCE: how do you get rid of the valet mode feature on a
try pressing the trunk button 3 times
Posted on Jan 25, 2010
  • 63 Answers
SOURCE: Remote strater is in valet
Try these two possible solutions
Press and hold valet button for 10 seconds. Release. LED should go out.
or
Insert key into ignition. Turn to on position (do not turn on car). Press and hold valet button for 10 seconds. Release. LED should go our
Posted on Jan 04, 2011
Car starter in valet mode
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
Dec 07, 2013 | Dodge Cars & Trucks
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
Where did they put the valet/program buttom on my 2004 Rendezvous?
This is somebody else's so;ution, but it might give you an idea on where to start. I always thought the valet switch was just a key that you gave to the valet. But inn this case out of my legue, my old dodge pickup doesn't hAVE AND MOST LIKELY NEVER WILL HAVE A VALET SWITCH. So check this so;ution oout and see if it gets you going in the right direction.
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings- Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
  • By avatar11.jpgBraunson Y309 days ago
    Braunson Y Level 2
    • 467 Solutions
    • 282 Score
Dec 19, 2011 | Viper Security and Remote Start System...
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
Led light is always on even when im driving and the remote start does not work....what do i gotta do....thanks
The LED light always on means the system is in valet. The remote starter should still work in valet so, check your hood pin switch to make sure the pin is making contact with the hood when the hood is closed.
Locate the valet swich under the dash. It's a black push button. Turn the ignition on, press and hold the button, count to five. Release the button, the light should go off. If there is a remote starter shut down installed, it should be located near the valet switch. It's a toggle switch that may still have a red boot over it. Flip the switch in the opposite setting. The remote starter should work afterwards.
Jun 28, 2011 | Car APS997A Two-Way Remote Start and...
What is the valet button and what does it do?
Valet mode on remote starts is there so that when you have someone working on your vehicle the start button for your remote start won't work. Say you're getting an oil change and for some reason the button is pressed, the vehicle wont start with the technician under it and no oil in the engine. In your owners manual it will tell you how to turn Valet mode on and also how to turn it off.
Dec 06, 2010 | 5303P LCD 2Way Security System with Remote...
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
Remote Car starter won't work
put your key in the ignition, then remote start it, if it starts, you need to either move the transponder loop of key or reprogram the transponder or take it to a remote starter shop
Jan 13, 2010 | 2003 Honda CR-V
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
