Back to:
Tags:
Toshiba Satellite P35-S609 PC Notebook
DVD drive problem (by 2 users)
posted by OverIT on May 13, 2007
I have two of these Toshiba laptops. One has an error with the DVD drive (Matshita DVD RAM UJ820S) and shows as an exclamation mark in device manager. I have tried reloading the drivers. SO..I swapped the drives from each laptop and guess what...the faulty drive works in the other machine and the good drive does the faulty thing in the original laptop. So I guess the DVD drive is ok but I cant get either to work in the original laptop. Any ideas would be greatly appreciated. thanks
Comment by OverIT, posted on May 16, 2007
Great news, I found a fix...turns out the problem was in the Registry, somehow an upgrade or installation program must have caused an alteration.
Fix problem by going into Regedit and do the following: Select first:
H_Key_Local_Machine\system\CurrentControlSet\
Control\Class
then go to:
Key Name {4D36E965-E325-11CE-BFC1-08002BE10318} Then delete all value data from the Upper and Lower Filters of this key.
Do not delete Key or MultiString values.
Then exit and reboot machine.
This problem can occur in any XP machine.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by pks4000, posted on Apr 15, 2008
DVD drive does not read discs and cant open them. So I cant install software.
J
Best Solution
posted on May 15, 2007
Thanks for Trying (70)
jackboy
Rank:Wiz Wiz
Rating: 77%, 3707 votes
Check the BIOS in the faulting machine- if is all OK- try downloading the latest driver.
theoriginay may be corrupt.
Failing that A Mobo fault.
Comment by jackboy, posted on May 16, 2007
Well done I will keep this in my little book[folder] of Fixes
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on DVD drive problem:
I don't want to Accept this solution
Solution #2
posted on Jan 06, 2008
Not Rated (0)
hanswurst
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
See also here:
http://support.microsoft.com/?scid=kb%3Bde%3B320553&x=9&y=14
http://aumha.org/win5/a/xpcd.php#problems
Both are basically dealing with the same solution as from OverIT, only a bit more detailed.
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
I wish to connect my Asus Notebook to the Yamaha reciever...
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
PC Laptops
My screen on the left has a bright pink color all the...
PC Laptops
I don't really have any problem with the laptop now... I...
PC Laptops
Pls help me to find SATA drives to be integrated on XP...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
