Question about Taylor Health & Beauty
Taylor 5576 body fat scale owners manual
Model 5576 owners manual
  • 2712 Answers
SOURCE: body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Posted on Aug 27, 2008
SOURCE: Watchers WW-87 Body Fat Glass Scale
Hi
At this web site bottom left hand corner there is an instruction manual
http://www.conair.com/weight-watchers-glass-digital-scale-p-667-2_60_38.html
Posted on Dec 16, 2008
fitnessbalan
  • 59 Answers
SOURCE: Need an owners manual for taylor mod 5757 bathroom scales
here is the owner manual from taylor http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Posted on Apr 22, 2009
  • 39 Answers
SOURCE: I have a Taylor body fat analyzer and scale model
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Posted on Jan 21, 2010
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
Taylor 5576 body fat scale owners manual Model 5576 owners manual
Try Googling (taylor)(5576)(manual) without parens.
Aug 28, 2017 | Taylor Health & Beauty
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
I have a taylor food scale model:3865BL and need a manual for it
I have Taylor the Biggest loser model 3865 BL and I need the Manual.
Apr 01, 2014 | Taylor Health & Beauty
I need a Taylor 5579 Body Composition Scale Manual
Check under your scale, mine had the instructions listed there
Feb 10, 2013 | Taylor 5568 Fat Scale Stainless Steel ()
Where do I get a manual ?
you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
Apr 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
I need an instruction manual for my taylor body fat scale #5568.
I posted the manual in my photobucket album here:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Nov 01, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
How do I get A manual for model 5599 scale?
Taylor customer service would be able to send you a copy of the manual either by mail or email. Here is their number. 1-866-834-3905. Here is their website. http://www.taylorusa.com/taylor-support
I hope that helps :)
May 14, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Health & Beauty Logo
394 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
