Question about LG Electronic Window Air Conditioner
Air conditioner I've got power to the unit but the control panel is dead-I push the power on button but nothing happens. Help!
  • doctorii May 20, 2009
    Bought last year - worked fine. Was off for winter, now looks like no power but there is power (confirmed). No lights, nothing. Is there a fuse or something that could have gone out? Don't want to have to buy new unit after only one year.
  • Tankedlush May 21, 2009
    Does your AC unit have the built in breaker in the power plug? My unit just quit powering up and the breaker in the plug does not pass the test procedure described on the plug. I am guessing either a short in the power cable or a bad breaker in the plug is making so no power gets to the unit.
Posted on May 13, 2007
Relay 1 passenger fuse box
Does the heater work ? blower motor pushes air out of the vent's ? A/C compressor doesn't engage ? I'm try to figure out what you have going on there . completely dead on dash panel ? Two fuse in the central junction box F2.14 10 amp an F2.20 10 amp these power the climate control panel . Relay one has nothing to do with it . If the fuse's are good you need a new control panel .
Nov 18, 2017 | 2002 Lincoln LS
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
I have a Frigidaire air conditioner. I've never had a problem with it,at all until a few minutes ago. It all of a sudden quit working. I pushed the reset button and tried to push power, but nothing....
First check the outlet the unit is plugged into. It may be dead, due to a circuit breaker being tripped. Also, the interior of the outlet may be damaged or has a loose wire.
If a circuit breaker was tripped, unplug the unit before resetting the circuit breaker. Then plug the unit back in and turn it ON. If the breaker trips again, there may be a short in the AC wiring or there is another electric appliance on that same circuit, that may be causing an overload, when the AC unit is ON.
Hope this helps you to start troubleshooting the problem. Thanks for choosing FixYa.
Aug 10, 2011 | Frigidaire Heating & Cooling
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
I bought an amcor 12,000 BTU portable AC two years ago. I used it for a month, never used it last year, and then tried to use it yesterday and it is dead. As in, there's no response when I push any...
When a sett is kep unused for sometime the possibility of faults can vary as when it is in regular use.The best way for a first hand info is to trace the line of power fromthe controller unit to the compressor.Check the line to the compressor, if the control panel is faulty, check compressor relay, check capacitor.
Since it is failure of power, it can also be a wire break.
Sep 01, 2010 | Amcor ALTL-12000E Portable Air Conditioner
My window unit will not come on. I have pushed the reset button and nothing happens. The power is on because the green light on the plug in on.
From the diagram everything is operated by the control board, unless it has a fuse on it you can replace looks like you gonna need one.
Jun 05, 2010 | Frigidaire FAM18ER2A Thru-Wall/Window Air...
Mach 15 Air Conditioner: There seems to be power to the unit but neither th...
Check to see if you have power going in and out of the Control Panel.
You could have power at the unit and at the control.
So you should check all voltage. At the unit and the control before buying or placing any parts.
May 16, 2010 | Coleman Mach 15 Air Conditioner
The went out in my condo and I have 3 samsung air
Unplug all the units, and wait for about a minute and plug it back. This is to reset all the units back to the
original condition. Hope this works.
Jan 05, 2010 | Heating & Cooling
I have an E8 error message on my Haier hwr10xc6 Thru-Wall/Window Air Conditioner
I had a problem with my Haier Air Conditioner also and was getting an E8 error message. We had taken the air conditioner out to clean it and when we put it back in all we could get was the E8 error message. We tried several different things so I don't know if it was a combination or luck. Here is what we did.
First we tried holding in all the buttons on the panel and another person hit the on/off button on the remote (per a suggestion on the internet). The fan stayed on, but the compressor would cycle and it would get cold for a few minutes then kick off, but we never could get the buttons on the control panel to work. Nothing happened when we pushed them.
Then we checked the thermostat (the little tube in the front) . The thermostat tube was touching the coils. We rearranged the tube so it was not kinked or touching the coils. It was then getting cold, but we couldn't control the buttons. So we unplugged it (reluctantly because it was cool then) and plugged it back in and it started working. Hope this helps someone! I don't know if what we did worked or the mother board got wet and just happened to dry out or something.
Jul 24, 2008 | Haier hwr10xc6 Air Conditioner
A/c will not work
Sounds like the control electronics are faulty. Replace control unit.
Jun 03, 2007 | Danby DAC9003D Air Conditioner
LG Electronic Window Air Conditioner Logo
210 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
