Question about Candy DQW150 Front Load Washer / Dryer
Dqw150 dryer element - Candy DQW150 Front Load Washer / Dryer
2 Suggested Answers
  • 1462 Answers
SOURCE: heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Posted on Jun 26, 2008
Machine seems to work, but will not empty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Candy DQW150 Front Load Washer / Dryer
I have a candy ciw 100t washer dryer and the water never gets hot, is this a cold fill washing machine?
to find if this is a cold fill machine only, just check the back and see how many hoses are fitted to it.I would assume it is cold fill and the problem is within the heater.
Mar 15, 2010 | Candy DQW150 Front Load Washer / Dryer
I am trying to change the element on a candy cna 166
Yes, you do have to lever it out, if you have removed the center nut completely, try and pull the metal plate as far forward as you can, this should expose the rubber seal, this is what is holding the heater in.
Lever round the edge of the seal, and try to force it out, be careful,as you can break the plastic moulding (expensive)
If this does not work, then try cutting through the seal with a stanley knife, and remove it piece by piece.
You will have no trouble getting the new one back in.
Plz rate my solution.
Thanks.
Jan 16, 2009 | Candy DQW150 Front Load Washer / Dryer
Hi, I have a Candy CIW100T washing machine and its recently stopped draining the water aty the end of the cycle. Can you help please? Thanks
Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
Plz come back if further help required.
Dec 02, 2008 | Candy DQW150 Front Load Washer / Dryer
Candy dqw 150 how to reset the dryer
i'm guessing a bit but the part that was reset was probably a resetteble thermostat on top of the dryer air manifold. take top off machine and you will see stats mounted on top of the air duct. one or more will have a little buttonin the middle. press this button and you will hear a slight click and the dryer will then work.
however, if the problem is reoccuring, then there is probably a lint blockage in the air duct causing poor air flow
Jun 26, 2008 | Candy DQW150 Front Load Washer / Dryer
Heating element Candy DQW150 Where is it please?
Apr 18, 2008 | Candy DQW150 Front Load Washer / Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Programme 1
make sure both solenoids have a working supply (if two fitted) at rear.
Nov 15, 2006 | Candy DQW150 Front Load Washer / Dryer
Candy DQW150 Front Load Washer / Dryer Logo
13 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
