Question about Mitsubishi VS-50607 50" Rear Projection Television
I have a Mitsubishi VS-50607 and it will turn on then off.
I just received a Mitsubishi VS-50607 from my uncle. I don't know a whole lot about them - trying to do some reading up on them. Anyway, as soon as I turn the tv on, the green LED light will come on and then the tv will automatically turn off.
  • ecuwins Jan 03, 2009
    I have the same exact issue.
    Same issue.
    Problem Solver:
  • 4 Answers
This solution fromtroylove solved my problem. troylove11
Rank:I have a Mitsubishi VS-50607 and it will turn on t - wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Mar 14, 2009
I have a Mitsubishi VS 50607 and the sound and color are good, but the screen is jumping. The picture is there but it is almost as if there are two of them. Anyone know of a solution?
Howdy,
CHECK and replace C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. REPLACE NO MATTER WHAT.
gOOD lUCK, BIG irish.
Dec 29, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I don't know how to get to the mirror and projection guns
the front trim on the tv pops off...there are screws all the way around the screen that you have to take out to remove he screen to get to the tubes and the mirror. once you pop the trim off youll see how easy the rest of it is
Feb 21, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Vs 50607
might be the convergence ic's
Oct 12, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
