Question about Aiwa PX-E860 Turntable
My turntable won't spin, needle wont go on record and it won't work automatically
Hey guys I am just wondering whats up with my record player as when I press the lift button the tone arm only goes up and does not go down on the record, also when I try and put it on manually it doesn't even touch the record. The record also doesn't spin. There is power going to it. If any of you guys could help me out it would be greatly appreciated. Cheers.
3 Suggested Answers
  • 5 Answers
SOURCE: aiwa lx 70 turntable needle arm
This is not a solution but it is information. I just got one of these turntables and the platter rotates but the tonearm does not move. I took it apart after downloading the service manual and found that there are two small thin rubber belts that due to age have fallen apart and "melt" when you try to pick up the pieces. One controlled the sideways movement of the tonearm "carriage", the other controlled the lifting and lowering of the tonearm. The replacements are expensive (I think around $18 each) and in trying to pop loose a worm gear with a pulley buit into it, so that I could try a cheap rubber band out just to see if the unit would work with new bands, I broke the stiff plastic "retainer" that by its shape was designed to be pushed out of the way a bit to allow the worm gear to be removed. The service manual, by the way, had all sorts of information about how to make fine adjustments, but said nothing at all about how to replace the belts. Unless removed there was no way to put the replacement band in place over the gear/pulley combination because there was no exposed end to slip a complete band over. So I think it was a bad design, made worse by the aging of the components that made the bands melt and the plastic "keeper" brittle so that instead of flexing out the way it broke. So I'm going to recycle the components. I did not find any reviews to tell me how good a component unit this was, so before you hire a pro to try to fix this unit you need to figure out if it will be worth it to you in the long run. Anyway, good luck.
Posted on Apr 12, 2011
STYLUSCITY
  • 271 Answers
SOURCE: Aiwa turntable px-e860: Hi, I've inherited
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Posted on Oct 13, 2011
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
Hi! I have a Pioneer PL 530 record player went on the fritZ!! Wont shut off?
Go to the vinylengine website. There are forums full of experienced users to help
Apr 07, 2015 | Pioneer Audio Players & Recorders
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
One side of my vinyl record will play fine but the other side won't spin right and the needle gets stuck on the record
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Dec 28, 2012 | Crosley 0187SST Turntable
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Aiwa PX-E860 Turntable Logo
27 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
