Question about Sewing Machines
I have an Elna Pro 5 DC. When you thread the chain looper thread it says to let the thread tail hang free. When I do that it either bunches up on the looper of doesn't engage with chain needle thread. (I had just finished sewing with it and changed threads the way I was supposed to and now I can't get the threading to work.) I'm frustrated!
  • 3 Answers
SOURCE: 2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Posted on Jun 27, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
Zenqi
  • 208 Answers
SOURCE: My white 2000 serger is dropping the thread on the
Could be as simple as poor quality thread (not using MaxiLock thread), the needles not inserted properly (the left is slightly higher than the right), a missing stitch forming pin on the needle plate, the needle bar being too high or a looper timing issue.
As the needles raise, the upper looper should move to the right with the right needle tip slightly above the eye of the looper.
Posted on Jul 19, 2009
  • 15 Answers
SOURCE: Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Posted on Sep 06, 2009
Overlocker elna 792d roll hem set up, please show how? To set settings?
3-thread rolled hem:
Remove left needle.
Settings as follows:
Upper looper 3-5
Lower looper 7-9
Right needle 3-5
Stitch length 1-1.5
Cutting width 3-5
Differential N
Jul 18, 2017 | Elna Sewing Machines
I have a white speed lock 234 serger and cannot get it to chain off. The thread bunches together
Yes, thread the upper looper first, the lower looper next.
***Make sure that you have the presser foot RAISED during the ENTIRE threading process until you get to the point of threading the needles.
The second to last step in the lower looper process is to make sure lower looper thread DRAPES over the top of the upper looper & thread, then both thread tails get pulled under the presser foot and toward the back of the machine.
Give each thread a little extra tug as it goes through the tension disk to make sure it is seated. Verify that all the threading steps have been followed. Any skipped steps, extra thread wraps, or incorrect threading will most likely cause a problem.
Make sure you have brand new needles before threading. If one is bent or damaged, you will probably have issues with skipped stitches.
Set all the tensions to the midway point (the factory standard for regular chain stitch). The tensions can then be tweaked when the machine is correctly creating a chain.
If the machine messes up, breaks a thread, comes unthreaded, etc., save yourself some time and frustration and RETHREAD everything from the beginning. Trying to rethread out of order usually fails!!!
Once you are more comfortable with your machine, you can try fishing a thread, but even experienced serger users still have trouble with this.
Aug 03, 2016 | Sewing Machines
L5 serger overlocker. Why don't the threads make a chain?
rethread machine, make sure u thread all steps
Jul 14, 2015 | Elna Sewing Machines
How do I thread the cover stitch looper on the Elna 744?
On my coverstitch,the lower looper swings out to the right so I can access the thread eyelet, wondering if yours is the same?. And i dont pull the thread up to he top, just leave a tail loose, make sure i swing the looper ack to the left, then close cover and stitch.
Mar 01, 2015 | Elna Sewing Machines
Thread lower looper on Elna 624 DSE. I have manual, still can't do it.
are you using a wire threader or tweezers to thread up? also some overlockers have a slide mechanisim on the looper so you can get to the eyelet, not familiar with this model but your manual should show the threading method. I usually turn the flywheel so the lower looper is all the way to the left and thread up the lower thread carrier, then turn flywheel again to move it to the right, then using the wire threader, I hook the thread from the left and bring it over to the right side, then thread up the looper eye. Hope that makes sense to you
Feb 21, 2015 | Elna Sewing Machines
Elna serger is not creating chain stitch
Rethread! Your lose looper has a "hidden" eye all the way to the left. You will find task easy with serger looper tweezers and serger looper Threader; however, if you turn hand wheel to the left, the lower looper will slide in that direction. Now you will see that "hidden" hole now. It takes practice, but you can still thread it without the extra tools! Hope this helps and if it does, I will get point for if you give me rating since I offer my time free to help others. Jimmy
Apr 06, 2012 | Sewing Machines
How do you thread a elna L-5 sewing machine
I found two sites with a manual for this model. Both are around $15.00 - sew4less and sewusa.
If you open the front of the serger, there should be a threading guide printed on the serger or on the inside of the door.
Raise the thread antenna to it's highest position.
Set the tensions to zero and raise the presser foot.
Turn the handwheel until the loopers are at their highest position - the handwheel may have a mark on it that aligns with one on the side of the serger to help with this.
Starting at the right, thread the upper looper first.
After threading, reset the tensions back to approximately mid-range.
Lower the presser foot and stitch a chain of thread to make sure the serger is stitching as it should.
May 01, 2010 | Sewing Machines
Elna Pro 5DC Serger
Sound to me you should get it serviced. Your timing is off. It also could be your needle make sure you use serger needles
Aug 08, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
