I have model # 2056-isx what does it mean when your stb button wont quit flashing continuosly
I put new batteries in it and the STB or cable lite just flashes
5 Suggested Answers
  • 74 Answers
SOURCE: Remote codes for a cable STB Explorer 3200 cable box and a Prive 26" TV
Call the provider of the box and they will walk you through it on the phone...usually.
Posted on Mar 25, 2008
SOURCE: HAVE A magnavox tb100mw9 for
Found a solution that works well...
I picked up a Sony RM-VL600 universal remote with learning capability. With this unit, I've been able to program all the functions of the TB100MW9 DTV Converter box.
I picked up this unit at Walmart for $25, but have seen it on Amazon for as little as $16.
This remote is a vast improvement over the remote that comes with the Magnavox DTV converter, and was easy to program.
Posted on Jul 07, 2008
SOURCE: mogen STB 2014 digibox
ebay sell them. about £10 inc postage.
Posted on Sep 10, 2008
SOURCE: How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Posted on Sep 02, 2010
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Code for Rank Arena STB
0092,0097,0927,0977 are the codes to check with this STB. If you wish to get more, 3 digit, 5 digit codes, check this link. http://electrohelponline.blogspot.com/
Jun 06, 2013 | Televison & Video
My new amino remote only works on my tv and not on my aminorouter. If a switch from tv to stb I can still use the vol button but the ch. button does not work. I cant change the channels on the amino...
Try re-coding the remote. Hold down STB and OK for a few seconds. Then when the red light is steady on the STB button you put in the code 000. By doing this you have reset the remote control. Also a good trick is to remove the batteries and put them back in. With that you are basically turning the remote off and on again. The good old restart.
Mar 22, 2010 | Philips PM3S Remote Control
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
99 yam 200 EFI, stb eng showing overheat, water pump, tstat, press valve changed, eng is running @ 120degrees, overheat horn on port side sounding, overheat light on stb flashing, overheat horn stops...
I would take it to a yamaha dealer and have them hook up a computer to it to see what kind of faults are flagging. That is a very odd scenerio.
Aug 04, 2009 | Boating
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Mogen STB 2014 digibox
Aug 29, 2008 | Big Button TV Universal Remote
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Electro Med Services...
