Question about Roper RAS6233KQ Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
ROPER 7 CYCLE WASHING MACHINE, ABOUT 5 YEARS OLD. Machine does not spin correctly and makes a noise like an unbalanced load but after repositioning the clothes several times, it still does it. I was thinking that a hook has broken on one side of the tub inside which would create an unbalanced load to occur all the time. I want to open the front panel and just see if there is something loose of broken on the agitator tub but can't figure out how to open the front panel. In the previous washing machine I had, you pryed up the top panel a little and could flip down the front panel, but that does not work with this roper. Any suggestions. Thanks. I email previously, but my email was incorrect.
  • Roper Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineRooper washing machine- unbalanced spin - rocking  - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 25, 2010
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Washing machine does not spin in any cycle
Hello, It can be one of two things, the contacts in the dial can have worn or broke causing the relay not to open or close to activate spin cycle.
Most likely it is your transmission or main gear for your spin cycle.
I hope its the dial which is an easy fix, but the trans is a big project IF the washer is worth it. You may consider looking for new/used washer if trans is bad. Good Luck.
Dec 11, 2012 | Roper Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
I have a whirlpool ultimate care 2 super capacity plus washing machine. We had it for about 7 years, just yesterday it stated to make an unusual noise when it was in spin cycle. As of today the washing...
My LSQ9549L is 7 yrs. old as well with an awful sound when spinning in high speed.
I've changed the agitator assy. as well as removed the drum and cleaned the soap build up on it.
Still makes a terrible sound in high speed spin. All other functions work.
Could it be the springs or coupling? I'm leaning towards it being the counter balance springs with it being rather weak. Could I be correct?
Your help is much appreciated.
Mar 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills up but wont switch to agitate
posibble bad timer. if it is skipping over the agitate.
Jun 15, 2009 | Roper RAS8445KQ Top Load Washer
Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Roper washing machine-unbalanced spin always-how to remove panel
tilt it back to see all the mechanics of it. and make sure that the machine is level in both directions. this site may help you with what parts look like www.repairclinic.com enter model number and scroll down to the red 100 and it brings up even more parts for your model. Good Luck
Jan 03, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Nov 07, 2007 | Whirlpool LSQ9600L Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
285 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
