Question about Nikon FG 35mm SLR Camera
Nikon FG 35mm
I just bought this camera, and this morning I was able to see through the viewfinder, but now it's just black. I can see the shutter opening when i rotate the lens aperture scale, but it's still just black.
also, this morning I was able to rotate the shutter speed/mode selector all the way, but now it only lets me rotate it from 0 to +2. what do i need to do to fix this thing?
i hope its something simple, and i'm just too inexperienced to know what i'm doing!
  • Amanda Lewis Jan 03, 2009
    okay, nevermind about the shutter. i read through other's problems, and when i set the thing on B, it popped open.
    now if i could just figure out how to get the shutter speed dial to rotate completely, we'd be good.
    Scholar:
  • 95 Answers
If its black when you look thru the viewfinder its likely because the mirror is stuck in the up position. It will often do that if the batteries are exhausted. Try replacing the batteries.
The mirror might release back down if you turn the shutter speed dial to M90. This is a manual release of 1/90 second for when you need the shot but don't have any power.
When you look in the lens opening and adjust the aperture dial, you are seeing the aperture open and close. Not the shutter. You need to open the back of the camera (without film) and take a photo to see the shutter curtains open and close.
You should have a read thru the manual to become familiar with the camera and its operation:
http://www.cameramanuals.org/nikon_pdf/nikon_fg.pdf
Posted on Jan 04, 2009
My nikon fg shutter is stuck but only works when set on m90 or b
Sounds like you got dead batteries. Try putting in a fresh set.
Dec 26, 2013 | Nikon FG 35mm SLR Camera
I recently bought a Nikon FG, and when i look through the viewfinder all i see is black. I made sure the lens cap it's on, and its still black! I need to replace the batteries, but will that fix the...
Take the lens off the camera and look inside. you should see a mirror angled at 45 degrees. If you do not see the mirrir, it is probably stuck in the up position and repair is necessary
r
Apr 22, 2011 | Nikon FG 35mm SLR Camera
Viewfinder eyepiece is black,(no objects can be seen)
Your mirror is probably stuck in the upward position. If so, your camera will need servicing.
Aug 29, 2010 | Nikon FG 35mm SLR Camera
My nikon fg 35mm when i looked through the viewfinder it appeared to be evwerything black so I took the lense off and pulled the mirror down but the mirror wont stay there it keeps going back up, what can...
Mirror lock up usually occurs when the batteries are dead.
Try replacing them, and NEVER pull down the mirror manually as you risk breaking the camera (if you have not done so already).
Feb 18, 2010 | Nikon FG 35mm SLR Camera
Cannot see through lens. took picture shutter closed, will not open up.
You have a bad capacitor. It is not worth fixing for these can be bought on Ebay for half the cost of repairing yours
Jan 14, 2010 | Nikon FG 35mm SLR Camera
Not letting take pics or advance film
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
Jul 04, 2009 | Nikon FG 35mm SLR Camera
Getting a black screen when i look through the viewfinder. i could see clearly through it this morning. also, i am unable to rotate the shutter speed dial. it only rotates from 0 to +2. what do i...
turn the speed dial to m90. that should reset the camera. No power from the batteries is required to operate the camera in that setting. fresh batteries may be needed
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Nikon FG shutter
By "stayed up", do you mean that the mirror remained in the up position so that you could not see anything in the viewfinder or do you mean that the shutter actually remained open? I do not remember the exact features on your camera, but in general, this is what I would do.
1) Remove the film from the camera and take a picture. Note if you see anything in the viewfinder. If you see nothing, the mirror is in the up position. Verify this by removing the lens and opening the door on the camera back. Look through the lens hole. If you can see through the rectangular hole at the film plane, the shutter is open. If instead you something is obstructing the hole, the shutter is closed. In any case DO NOT TOUCH THE SHUTTER! The shutter is what is covering the hole.
2) If the mirror is in the up position, check to see if your camera has a feature that allows locking the mirror in the up position. Some cameras have this feature to allow use of lenses with very short focal lengths. If this is the case, simply unlock the mirror.
3) If the shutter is the problem, your shutter speed may be set to "T", which stands for time. In the time exposure mode, you press the shutter release once to open the shutter and a second time to close the shutter. Cameras with a "T" setting also have a "B" setting, which stands for bulb. This is a throwback to the old days when it was common to use air-powered shutter releases rather then cable releases. The bulb was a rubber bulb that you squeezed to force air through a tube and push a pin to activate the shutter. The "B" setting keeps the shutter open as long as you hold the shutter release in, but as soon as you take your finger off the shutter release, the shutter closes. Both of these settings are used to make timed exposures. If you find that the problem was that the shutter was set to "T", set the shutter speed to 1/25th second or so and try again. The following sequence should occur; the mirror will flip up and the viewfinder image will disappear, the shutter will open for the prescribed time and close, the mirror will return to the down position and you will again see through the viewfinder.
If this does not work, you may need to take it in for repair.
Nov 18, 2008 | Nikon FG 35mm SLR Camera
Nikon FG 35mm SLR Camera Logo
513 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
