Question about Lenovo ThinkPad T420 Notebook
The hardware wireless radio switch must be in the on position to use the wireless radios
Bluetooth is not working
5 Suggested Answers
mercadoarvin
  • 384 Answers
SOURCE: Wireless radio on Lenovo Y510 turned off even
Hi There and Welcome to Fixya!
Another way to turn on the wireless radio on your Lenovo Y510 is to press and hold the "Fn" key, then simultaneously press the "F5" key.
This is an alternative way to switch the wireless antenna on or off without using the physical WIFI switch.
Hope this helps,
Thank you for using FixYa.
Posted on Mar 12, 2011
  • 366 Answers
SOURCE: Internal wireless device set to Radio Off, how do
To switch on is normally a keyboard key. or a switch some where on the laptop it self. look along your number keys for a wireless signal logo, if its blue there will be another key you have to press with it, normally a fn key.
you can do it also by going to start settings control panel or just start control panel and network conections.
find your wireless conection and right click it and goto properties. there will be a tab on top for the wireless card and the first option inside this is on or off. hope this helps.
Posted on Dec 01, 2009
  • 128 Answers
SOURCE: Cannot turn on wireless radio on Lenovo Idealpad
Press FN+F5 button together on the keyboard to have the settings for display pops up on the screen. Check if the radio button was turned on both for wireless and bluetooth connection. If the radio button was off, just click ON and that should set the wifi to turned on. Always make sure that the wifi switch was set to on as well.
If this didn't fix the problem, kindly reinstall the wifi adapter driver by downloading the driver from the manufacturer's website. after reinstallation kindly reboot the computer.
Please leave comments if you have any other questions.
Cheers~
Posted on Jun 20, 2010
  • 5 Answers
SOURCE: I have IBM thinkpad R60
Please follow these steps to make it work:
1. Uninstall the wireless driver using Add/Remove Programs
2. Uninstall the Hotkey utility using its Setup program (uninstall is an option in the Setup app; it doesn't appear in Add/Remove Programs control panel)
3. Restart
4. Delete the Hotkey folders from C:\Program Files\Lenovo\PkgMgr [key step!]
5. Reinstall the Hotkey Utility and the wireless driver (don't reboot if prompted)
Regards.
Posted on Jul 29, 2011
How to enable bluetooth
Your computer has to have a bluetooth radio. You can check
Control Panel > System and Security > Device Manager
Do you see a Bluetooth Radio listed?
If not, you don't have BlueTooth on your computer so you will have to add a BlueTooth device by plugging one into a USB port.
If you have a BlueTooth radio, go to Control Panel > Hardware and Sound > Device and Printers > Add a Bluetooth Device
This option is used to connect a blue tooth device (e.g. bluetooth headphons) to your laptop through your bluetooth radio.
See this Windows web page for more information.
Set up Bluetooth enabled device
I will respond to any additional questions you have.
Aug 05, 2014 | Dell Inspiron Computers & Internet
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Jun 18, 2014 | Gateway M6307 Notebook
How to activate bluetooth using wireless switch
Step 1 Find the wireless switch, located on the front of the E5400, to the left of the touchpad.
Step 2
Slide the wireless switch into the "On" position to enable wireless radio communication on the Latitude.
Related Reading: How to Turn on Wireless on a Dell Latitude Laptop
Step 3
Click "Start ' Control Panel ' System and Maintenance ' Device Manager." Double-click "Bluetooth Adapters."
Step 4
Right-click the Bluetooth driver and then select "Enable" from the context menu, if available.
Step 5
Navigate to the Dell Support website in a Web browser if the Bluetooth Adapters category is not listed in Device Manager.
Step 6
Click "Start Here," then "Drivers Home." Click "Choose From a List of All Dell Products," then "Continue."
Step 7
Click "Laptops," "Latitude," then "Latitude E5400." Choose your operating system from the associated drop-down menu.
Step 8
Expand "Network." Click "Download File" next to the Bluetooth driver, then "Download Now."
Step 9
Launch the EXE file when the download completes. Follow the on-screen instructions to install the Bluetooth drivers to the computer.
Step 10
Restart the Latitude following setup to begin using Bluetooth on the E5400.
Jun 16, 2014 | Dell Latitude E5500 Laptop
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
Dec 20, 2010 | Computers & Internet
How do i switch my wireless on amilo pro 2040 laptop
You have to look closely at the function keys; one of them should have a small triangular shaped antenna symbol on it. Say it's F6. Then locate the "Fn" kay lower left on the keyboard, adn press the Fn + F6 combination (substitute F6 with the actual key with antenna symbol) - the Wireless LED should light up.
Some AMILOs had a separate witeless pushbutton switch on the front edge of the computer.
Jul 15, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have a canon MP600 which I plug into my laptop when I need to print, however current setup is such that this a pain as I have to sit by the printer and when I have a lot to do I then cannot be in a...
yes vista, is non friendly as old oem hardware, so you must have a vista ompatible hardware. the bluetooth only works well bellow 5m radio, you can use a wireless router with usb port for printers, and your problem, is less confusing, but choose a good hardware, or else u giveup the printer.
Nov 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My video is not working on skype, says ''bluetooth video service not running'' please help
Go to Device Manager and see if you have section named Bluetooth Radios and your BT adapter listed under that. usually Bluetooth and Wireless adapters are controlled by a single hardware switch.
see a service called “Bluetooth Support Service” and it is dependent on “Remote Procedure Call (RPC)”, check those two, under Start>Run>type services.msc whether running or not ....
You can try to re install the driver for bluetooth ...
Aug 27, 2009 | Computers & Internet
How do you turn on the wireless function on the esprimo v5535?
hai
According to the laptop's quick guide this is how you enable and disable your wireless:
Radio components: Wireless LAN/ Bluetooth/UMTS
The installation of a wireless LAN module not approved by Fujitsu
Siemens Computers GmbH voids the permits issued for this device
(see chapter "Technical data", Page 22).
Depending on the device variant, wireless LAN, Bluetooth and/or UMTS may be integrated in your notebook.
On delivery, WLAN components are switched on, Bluetooth components off.
Switching the radio components on and off
Start the WirelessSelector using the key combination Fn + F1 .
The WirelessSelector enables you to switch the radio components activated in
BIOS Setup on and off individually.
BUWlMuireTtlSeososthLAN
Press the key combination Fn + F1 to start the WirelessSelector.
The radio component indicator will be illuminated when one or more
radio components is switched on.
If you switch off the radio components, the Bluetooth module, UMTS and wireless LAN transmission unit (antenna) will also be switched off.
You can enable or disable the radio components individually.
BIOS Setup allows you to specify which radio components can be switched on
and off using the key combination Fn + F1 .
Only those components that have been activated in BIOS Setup can be switched on and off using the key combination Fn + F1 .
Conversely, components that are deactivated in BIOS setup cannot be controlled using the key combination.
You can also activate and deactivate the radio components individually in the BIOS Setup. You must have assigned the supervisor password in order for this function to be available.
Pay attention to the additional safety notes for devices with radio
components provided in the "Safety" manual.
Details on using Wireless LAN can be found in the online help system
included in the Wireless LAN software.
You can find more information on how to use Bluetooth on the CD you
received with your Bluetooth software.
Sep 06, 2008 | Siemens Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Lenovo ThinkPad T420 Notebook Logo
274 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
