Question about Electrical Supplies
3.4kva silent digital inverter generator XG-SF2500 motor runs but no AC voltage.What to do?
  • 13 Answers
SOURCE: I have a new Briggs&Stratton generator and it's
Is that all the load on the generator? If so, it's probably just not regulating. Try loading it up with about 250W worth of lightbulbs (like one of those construction floodlights), it'll probably settle right down. The inverter charger is doing you a favor and protecting itself.
Posted on Mar 08, 2009
  • 27 Answers
SOURCE: Kohler 12res AC breaker flipping with no error listed
wat size c/breaker
6600 divide 240 = amp
rule of thumb
Posted on Sep 06, 2009
SOURCE: No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Posted on Apr 02, 2010
puertobori
  • 7733 Answers
SOURCE: McCulloch 2000W Inverter Digital Generator #
download a manual at ->link.
Posted on Oct 13, 2010
SOURCE: Digital Inverter Generator XG-SF3600 running but
i have the same problem. I have AC from the windings but nothing leaving the inverter module..Its a sealed unit. There is virtually no parts back up service & if you can track down parts, they are quoting from $ 400 to $ 700 for replacement..If you expect this gen set to last like a honda or yamaha your mistaken..Dont buy chinese unless your short of folding stuff or you only use your gen set occasionally & for those that have had no trouble with theirs, its only a matter of time. trust me, they are a disposable item..
Posted on Nov 16, 2012
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
My honda generator is sending high ac voltage
adjust the engine rpms to drop the voltage
replace the voltage regulator
Eu6500is generator trips to red unload when ac is on
Air conditioner compressors require a greater amount of electricity (measured in both volts and amps, but the amps are what is causing the overload). You will need a larger generator to run your AC. You might be able to run a smaller AC unit, but always check the Amps required and compare that to the Amps the circuit breaker on the generator is rated for.
May 30, 2016 | Honda EU6500iS Inverter Generator
What is the minimum volts required to run 1.5 ton 5 star AC?
Low voltage will burn out all the motors Higher currents will ruin the start capacitor on the compressor and fan motors too. 220 vac is the minimum. You have to allow for inrush or start up current which most likely is the cause of the under voltage. You'll have to get a larger capacity stabilizer.
May 25, 2016 | LG Heating & Cooling
Overload light eu3000 comes on with trailer roof ac never did before
The battery is really only there for the electric start. Put a digital volt meter on it while running it under the load of the AC unit. Or if it goes off on the overload with the AC unit, try a variable load like an electric heater or two that you can switch on in steps. Most space heaters or hair dryers have a 1000w, 1250w 1500w so you can increase the load. Watch what the voltage does. If at 1500-2500 watt load the voltage starts to drop drastically, say from 125v down to 90 or 80v as the load increases, that usually indicates a problem with it not getting enough fuel. On these inverter generators, the carburetor is controlled by the inverter by the use of a throttle motor. As the inverter senses the demand for more power, it increases the throttle to deliver more horse power of the engine, thus meeting the demand for more electrical power out.
I have seen a couple things cause this. A partially plugged jet in the carburetor can cause it. A bad throttle motor (Part# 21) on the top of the carb can go bad. I even had one that I caused myself by not putting the little spring (part #20 on the exploded view of the carb) that sits under the throttle motor in correctly.
Jul 10, 2012 | Honda EU3000iS Inverter Generator
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Digital Inverter Generator XG-SF3600 running but no current
Sep 06, 2010 | Electrical Supplies
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
