Question about Sharp EL-2630P Calculator
How do I set the decimal on a Sharp EL-2630PIII adding machine?
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
  • 20 Answers
SOURCE: how do you put the adding machine tape into the
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Posted on Mar 08, 2010
SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Posted on Jun 16, 2010
SOURCE: hi! I am using the Sharp EL-735 and I don't
Setup DSP TAB
then you can choose between 0-9 decimal places
Posted on Jun 17, 2010
SOURCE: sharp adding machine settings
What should the settings be set at??
Posted on Sep 01, 2010
How can I get my sharp calculator to add and subtract correctly?
Could it be that it has adding machine logic and not calculator logic?
Let's do an experiment. 3+ 3+ 5-. Is the answer 1?
If so, it is working like an adding machine. Every number you enter is considered positive or negative and it keeps a running total.
Let me know if you have any questions.
Good luck.
Paul
Feb 25, 2015 | Sharp "el-2630piii desktop calculator,...
Why won't my calculator add or substract?
It looks like it may have adding machine logic.
Do this key sequence:
5 + 5+ 6-. Is the answer 4?
Each number you enter is positive or negative and it is just keeping a running total, rather than adding and subtracting numbers.
Let me know if this helps.
Good luck.
Paul
Jul 22, 2014 | Sharp EL-2630PIII Desk Calculator 12-Digit...
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
Sharp adding machine settings
Dec 31, 2008 | Sharp EL-1197PII Calculator
How do I avoid using the decimal when typing a number with no 0s
If I am not mistaken you are trying to set your decimal in dollars and cents correct? Well, if I am understanding your question correctly; you move tab that has F 6 3 2 1 0 set that to the 2 and then there is a tab that says "K * A make sure that is set to the A as well. Hope that helps.
Nov 19, 2008 | Sharp EL-2196BL Calculator
I want to know what is the fraction equivalent of the following decimals
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=662433c8924616b3264931192aff1225&q=Sharp+EL-2630PIII
Feb 01, 2008 | Sharp EL-2630P Calculator
Sharp EL-2630P Calculator Logo
339 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
