Question about Exercise & Fitness
My trojan inspire 330 read error code E1 - Exercise & Fitness
3 Suggested Answers
  • 33 Answers
SOURCE: For the trojan solitude 2 platinum treadmill: it
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should hopefully make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: Trojan solitude 2 platinum shows error code E1.
Your problem should be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Teach me how to fix aircon says e1?
Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Best wishes.
May 08, 2018 | Heating & Cooling
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My Trojan treadmill shows E1 error code.. Please advise . thanks
    please test the following steps. God bless you
    ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
    from the speed setting.
    Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
    the signal is not reaching the display.
    see the diagram attached.6b49b8f5-6e36-4223-8f25-0adeb1611452.giffinally reset the small switch, use small pencil erase for to click. the switch is to side the main power
    Aug 24, 2013 | Exercise & Fitness
    E1 ERROR on Trojan treadmill
    Step 1:
    This is probably a1) faulty speed sensor or the speed sensor adjust see the diagram attached..2) Clean it very weel 3) pluged very strong.
    Step 2:
    also possibly a a)faulty motor tes the input voltage , if there are the motor need repair see my personal TIPS for motor help. b) lower board, measure the output voltage board for inpt voltage motor, if there are NOT the board is faulty, replace see the block diagram and wiring diagram.
    . The error codes will differ between makes and models but could be e1.1_7_2013_4_49_28_pm.jpg1_7_2013_4_49_42_pm.gif
    Step 3:
    Finally see the video and LUBE the deck belt and rollers bearing too, proceed according.
    Jan 07, 2013 | Exercise & Fitness
    Error Code E7
    To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
    Apr 22, 2012 | Exercise & Fitness
    Trojan solitude 2 platinum shows error code E1. How can we fix it?
    Good luck.
    Jul 13, 2010 | Exercise & Fitness
    I have laars heater model ht 330. there is no hot water and the heater displays error code E1
    E1 is only the first part of the error code. There should be one or 2 more digits being displayed, alternating with the "E1" display. Unless you provide the other 2 digits of the error code, I can't help you.
    You can get the user manual for your boiler/water heater with the error codes from here:
    http://www.blueridgecompany.com/documents/LaarsHT330.pdf
    Please, get back to me if you need any more help
    Alex
    Mar 21, 2010 | Heating & Cooling
    Error message E1
    hi there we have an E1 error after 7 seconds of operation??
    Apr 09, 2009 | Exercise & Fitness
    Exercise & Fitness Logo
    119 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
