Question about Samsung Televison & Video
Service code Samsung projection tv model sp43j8hf
Require service codes for correcting convergence for Samsung projection tv model sp43j8hf
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-61HX42F, Need service
the service menu wont help. you need to replace both convergence ics number STK392-110 . you can get replacement ICs at the following link and they provide free instalation instructions with pics so you acn do the repair yourself in about 45 minutes and save over 400.00. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 18, 2008
SOURCE: PT-51HX40b chassis BP819
if you get to the red chk press the power button on remote numbers should appear lower right each time you hit power button nummbers change keep going till 00v00 appears press ch up then it should read oovo1 at this time press vol up now your ready
press 1 to toggel colors
use vol and ch buttons to move cursor
press mute to choose to addjust
press7 to save data
good luck
Posted on Mar 08, 2009
SOURCE: hitachi projection tv
We had a tech replace the digital convergence chip #2375223. It solved the color alignment issue.
I'd appreciate a copy of the manual for Hatachi 60sx8b emailed. Thank you!
Posted on Mar 18, 2009
SOURCE: convergance circuit board
TRY LOCATING THE COLOR CONVERGANCE IC CHIP ON THE BOARD , IT WILL BE MOUNTED TO AN ALUMINUM HEATSINK PLATE ON THE BOARD. LOOK FOR IT TO BE ATTACHED WITH A SELF TAPPING SCREW AND SPRING CLIP. THIS CHIP IS RECTANGULAR AND HAS 11 CONTACT LEGS SOLDERED INTO THE BOARD . ORIGINAL EQUIPMENT CHIP IS STK730-130 , AVAILABLE THROUGH SUBURBAN ELECTRONICS WHOLSALE FOR $4.59 +SHIPPIMG AND HANDELING. A TV REPAIR SHOP SHOULD BE ABLE TO SOLDER YOUR NEW CHIP IN FOR YOU,AND IF YOU HAVE SOLDERING EXPERIENCE REPLACE IT YOURSELF THAT IS WHAT I DID AND THE TV WORKS GREAT!
Posted on Sep 12, 2009
My 2000 rear projection tv colours are out of wack ,but colours are high on one side and low on the other side need codes or something the model is pt-51d30cb
SOUNDS LIKE A CONVERGENCE PROBLEM. THE CONVERGENCE CIRCUIT HAS FAILED. NOT CORRECTING THE PROJECTION GEOMETRY. THIS WILL REQUIRE PARTS REPLACEMENT.
Dec 27, 2009 | Televison & Video
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Samsung rear projection television HCN4226WX/XAA
Dead Samsung
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Most rookies will not successfully complete the repair and probably do more harm than good.
Sometimes when the convergence chips fail, the TV senses the changed load condition and shuts down.
Unplugging the blue, red or green convergence connector on the convergence board removes the overload condition if the IC is shorted and allows the tv to run, with one color missing.
This is done with the tv unplugged. Then plugged in and turned on to see if it starts. Turn off immediately if you here it start.
Now you know if convergence failure caused the shutdown. You can repair the convergence circuit if that is the problem.
If this has no affect, then you could have a number of different faults in Vertical output, Power Supply or HV circuits that require the expertise of a qualified service person. This would be a bench repair in most shops.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
May 27, 2008 | Samsung HCN4226W 42" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Hitachi service code 5
Hey.
Service code 5 is a convergence problem. As far as how to fix it. That depends on your level of expertise, it may require your checking resistor values at some point. If you do take it on your self I recomend looking online for copies of the service manuals first.
Feb 27, 2008 | Hitachi 51G500 51" Rear Projection...
Electronic schematic for Pioneer sd-p4571
· http://www.eserviceinfo.com/most_popular/list_5800.html
· https://www.manualsparadise.com/Sho...model=M31429247
· https://www.completeservicemanuals.com/panasonic/digital-camera/lumix-dmc-fz5-service-manual/prod_86.html
· http://www.user-service-manuals.com/Sony/UP.shtml
· http://www.schematicsforfree.com/
Jan 17, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Need the codes to enter the service menu
First, you will need to fix the convergence problem by replacing
the convergence IC's,then activate auto focus and last,if necessary, enter the servicer mode................T.
Nov 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
