Question about Sewing Machines
How to get a zigzag stitch on a lervia kh 4000 sewing machine
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
  • 6 Answers
SOURCE: when making a straight stitch or Zigzag stitch,
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Posted on Feb 21, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
My sewing machine only sews zigzag stitches never a straight stitch. Why?
We need to know the make & model machine.
If it is an older mechanical Kenmore, more than likely it is seizing due to old oil turning to glue inside the machine. Unfortunately, these old machines were made too well as the manufacturers never anticipated the machines would be around for 50 years. However, as mechanical machines they do need regular cleaning and oiling with a good quality oil, ie liquid Tri-Flow Synthetic Lube or "good quality" sewing machine oil.
Either the stitch width regulator is broken or stuck or the mechanism that drives the needle bar is stuck. With plenty of time, patience, elbow-grease & Tri-Flow, your sewing machine will probably be sewing like new.
I've used the following method to free up some great old mechanical machines and they operate like new again:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Also, be sure to change the needle frequently, ie every 8-16 hours of use. Most sewing issues can be resolved with a new needle.
May 05, 2017 | Sewing Machines
Has someone got a manual for lervia 564
This site lists manuals for Lervia (although not your model), however, sometimes machines are sometimes similar enough that other manuals are helpful:
http://safemanuals.com/page/search/Lervia+564
Kompernass LERVIA KH 4000 Operating Instructions Manual
May 27, 2016 | Sewing Machines
Can this machine do zigzags?
The Sew Dlite 11401 shown on Amazon here, http://www.amazon.com/DLite-Supreme-Portable-Sewing-Machine/dp/B0006BDG8Q , does not do zigzags. It only does straight stitches. There are similar models that have a stitch width lever. Those do zigzag stitches and straight stitch when in the zero width mode.
I hope this helps.
Aug 25, 2013 | Sew D'Lite 11401 Mechanical Sewing Machine
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Nov 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
79 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
