Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Pro heat 57g7-g carpet cleaner no water coming out
No water coming ouy
SOURCE: I have a Bissell pro heat carpet cleaner, the
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Posted on Mar 01, 2009
earl5445
SOURCE: Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Posted on May 06, 2009
rustysheriff
  • 344 Answers
SOURCE: I need a manual for the bissell pro heat carpet
Try here:
http://www.bissell.com/Product_Search.aspx?Criteria=pro+heat+carpet+cleaner
Please rate accordingly
Posted on Jun 07, 2009
Vac Belts
  • 701 Answers
SOURCE: where can i obtain a manual for a power steamer
You can view the manual here:
Bissell Powersteamer Manual
Posted on Dec 02, 2009
  • 25 Answers
SOURCE: Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Posted on Apr 24, 2010
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
I have a pro heat turbo cleaner and the water does not come out when the trigger is depressed
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel power wash pro heat
Look under neath there is a **** hole. It may be plugged
Feb 09, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Thankyou,
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
