Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
KP-46WT520 I replaced all 3 diodes as told and tv still does not turn on and still flashes 9 times. I am able to turn on tv using the code...display-5-vol-power and it works that way. any other suggestion? thanks
  • 2 more comments
  • rskc736 Jan 03, 2009
    Still blnks 9 times
    to make sure I replaced right part. what part number is correct for the dioide D6117? thanks
    Yes, picture is perfect in service mode. Just have to watch tv with all the code numbers on top and bottom of screen.
  • rskc736 Jan 04, 2009
    at the botom of screen it says..
    F/A 00000000 11111111
    CBA 00000000 00000000
    are these the correct ones?
  • Sony Master
  • 5,138 Answers
IC8002 # 670581001 on D board .Ater replacing 3 diodes how many times does it blink now?
Posted on Jan 03, 2009
  • 3 more comments
  • ladywinn
    ladywinn Jan 03, 2009
    OK then you may have to replace G -Board Part# A1065549A/ Do you see a picture when set comes on with self Diagnostic mode? or Any of Error Codes If not then replace your vertical IC .
  • ladywinn
    ladywinn Jan 04, 2009
    What Are the codes they tell you which circuit has problem.????
  • ladywinn
    Now How to clear codes and see if TV remains Playing Display,5,vol+, then power) Now Press 8 and Enter this will return everything back to Factory Presets.Im not for sure on # D6117 ,if you have wrong diode it maybe why set will not come up wondering if it is a Fast switching Diode? What is # on old doide i have NTE book can look it up.
  • ladywinn
    ladywinn Jan 07, 2009
    Was wondering hows the repair on TV going?
  • ladywinn
    D6117 is a General Purpose Fast switching diode NTE 552
TV won't turn on, standby light just blinks 9times off and on
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
Feb 03, 2010 | Sony KP-46WT520 46" Rear Projection...
Sony kp-46wt520 blinks 9 times
you can use basic power supply diodes ecg 125s or diodes rated at 60 herts at 2.5 amp. these type of diodes are common to alot of power supply diode bridges and if you have any junk electrical boards then you could borrow them used, don't worry they will last longer than the original new ones which were not very efficient from the start.
Sep 07, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv wont turn on
Your lamp need to be check or replace it.
Jul 24, 2009 | Sony KP-51WS510 51" Rear Projection...
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
My tv blinks 9 times and wont come on?
Replace 3 Diodes D6301-D6116-D6117 .
HAPPY NEW YEAR!
Jan 01, 2009 | Sony KP-46WT520 46" Rear Projection...
Light flashes 9 times
that means it has an audio error.
Dec 31, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-46WT520
Replace Diode 6301 and D6116,6117
Nov 21, 2008 | Sony KP-46WT520 46" Rear Projection...
Stand by light flashes 9 times
replace the zero crossover detect diode in the power supply.
Nov 11, 2008 | Sony KP-57WS520 57" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
341 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
