Question about Goldstar Microwave Ovens
Goldstar over the range mircowave model mv13108 will not heat up, 1.6
Made in 1998
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: goldstar mircowave model 1310b parts manuel
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
Posted on Jan 11, 2010
Ineed a manual for a MV1608WW
http://www.searspartsdirect.com/partsdirect/part-model/Goldstar-Parts/Microwave-Parts/user-manuals/manual-downloads/Model-MV1608WW/1366/0123370?modelNumber=MV1608WW&diagramPageId=&documentId=
Sep 04, 2013 | Goldstar MV1608WW 1.6 cu.ft. Over The...
I have a goldstar model mv1526b microwave it has a weird hum and wont heat. Everything else seems ok.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 25, 2011 | Goldstar MV-1526 Microwave Oven
Goldstar mircowave model 1310b parts manuel theres a plate at top of cooking area thats is burned two plastic pins hold it to top of mircowave need replacement, help curtis
Jan 09, 2010 | Goldstar Microwave Ovens
Microwave not cooking
I would say yes, this can be fixed. It's most likely a relay with burned contacts.
May 02, 2009 | Goldstar MV-1526 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Mircowave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a over the range microwave and I need the support bracket the holds the unit up. where can I get one. model number is goldstar MV161OWW is there anywhere where i can order? and it there a...
That model should be MV1610WW.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Sep 25, 2008 | Goldstar Microwave Ovens
Microwave Ovens Logo
55 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
