Kenmore 110.92575110 After reading about the possible lid switch problem on this site, I placed a toothbrush handle at an angle to depress the door within the notch. The washer is currently spinning. I did not, however, understand the instructions for repairing the switch. Are any diagrams available?
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Frigidaire top load washer does not spin until I depress the lid lock switch
Is the strike still in place on the lid? What is the model number?
Nov 20, 2013 | Frigidaire Washing Machines
My front load washing machine model ATF8000FE1 does not recognise that the door is closed. All the other lights are green when I select the mode but that light not. I do not know if there is a problem with...
There should be a peg on the door that depresses a switch. Make sure the peg is not broken and then take something that looks like the peg and see if the switch is loose. The back end of a toothbrush is good for this. Stick it in the slot for the switch, The switch could also have failed but this is a good place to start.
Mar 16, 2013 | Washing Machines
Dryer Kenmore
Yes, but check the breaker first. turn off/on to check. Remove the screws at the lint filter. remove fint filter. Use a thin putty knife at thr front between the top and door support to depress the spring clips holding the lid down, one at a time pull each side to disengage clip. Lift lid. The door switch is above the door inside under the lid. ALWAYS UNPLUG BEFORE WORKING ON ELECTRIC APPLIANCES.
Sep 20, 2009 | Kenmore 63942 Dryer
Spin cycle is not working
All washers have a safety switch that prevents the spin cycle if the lid is open. Washers will still agitate even if a washers lid is open.
This is the most common problem with failure to spin. It is an easy part to replace, and an easy part to check if this is the problem, if you are half-way handy. You will see the plunger that is depressed to close this switch either somewhere around the opening for the door on the machine, or sometimes the plunger is on the door itself as a plastic protrusion that mates into a hole in the door opening of the machine, to activate this switch. If you are lucky, you may find it is just the plunger on the door that has broken off, or the switch on the machine is just loose and needs screw tightening or remounting.
If you have a computer, which you do because you are reading this, search for this Lid or Door Safety Switch and your washer model on Sears/Kenmore web site, or just the web period, and you will see a graphics of the location of the switch and how to access it. You can test the switch to see if this is the problem by shorting across the two wires that connect to it. Be sure to unplug your washer while handling these wires, and plug it in briefly just to test. Do not do this at all if you are not handy and familiar with 115VAC safety precautions.
Sep 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin cycle doesn't spin out
there is a switch which detects the lid being closed. if this switch is bad the spin cycle will not engage. also, there is a little actuator which enables this switch thru a hole in the top and if has gotten broken off will also cause this problem. look for a little door at lid level and staying clear of the washer push a small rod into this hole. if spin starts the actuator is gone, if not the level switch is bad. make sure the function switch is in the spin position and activated.
Aug 30, 2009 | Kenmore Washing Machines
Kenmore washing machine 6 series model 110. stopped spining. I have pushed in the lid switch and I hear noise like it wants to work but it doesn't.
Test the Lid switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
Jul 23, 2009 | Kenmore 24032\24036 Top Load Washer
Won't agitate unless manually depress lid switch
There is a plastic "finger" that is attached to the lid that would normally close the switch when you close the lid. Is it still on the lid? If not, you can go to the sears web site for repair parts. You will need your model number.
Good luck.
Regards,
Jul 04, 2009 | Washing Machines
Washer wont drain
Go to sears web site and enter model number of machine and look for lid switch. The cabinet of the machine needs to be removed to replace this switch. Go to Appliance Guru for details of removing the cabinet
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Could the lidswitch be causing the problem as well
yes could be the lid switch depending on the model they are held on by two screws ive seen one break and let the switch hang at an angle so that the lid strike cant fully depress it
May 19, 2008 | Kenmore 23812 Top Load Washer
Spin cycle doens't work
Your hand probably won't depress the lid switch far enough to actuate it. Use a pencil, pen or old toothbrush handle to press the switch down and see if spin starts. If it starts, the lid actuator is likely broken or out of alignment.
Apr 09, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
