Question about RCA P61960 61" Rear Projection Television
Rca model P61960 bowed screen and convergence is off
Screen bows in center top and center bottom some of the sides of the picture are cut off and the convergence is off
  • 13 Answers
SOURCE: picture bows on top and bottom of picture......
hi my asteamed coleage is correct in most cases.I have been a factory warrenty tech for rca since 1985. your set ctc 195 chassis has 2 boards 1 digicon board (digit convergence board) and 1 small convergence board called conver power supply) this board produces power to digicon board There is a pos 47volts and neg 47volts along with 15 volt supply ) i think if looking from back of tv (with back off) in the upper right corner you will see a small green board (4inc long by 2inch ) on that board is a silver metal piece going from top to bottom is a small black (kind of rectanggular black chip it has a clip ontop remove screw to see num on chip is 730-020 change that . as for your ques about customer convergence it's hard to find if you hit menu move down to vidio menu (you will get color,brightness and so forth but keep going down it will come to CONVERGENCE hit + key hope me and colleage helps fix tv from MILWAUKEE WIS HEY GOOD LUCK
Posted on Aug 11, 2006
  • 308 Answers
SOURCE: rca 52" p52960 convergence bows
I wish it was that simple. On this chassis there are many parts that have gone bad in the past to cause this very symptom. So many in fact that there is a repair kit available that contains common failure parts p/n 250686-KIT. This is NOT a DIY project as many of the parts are small and would be hard to locate and impossible to replace by anyone not having superior soldering skills. It would not surprise me if the repair on this set would set you back about $350. If you can get a free estimate, great, but if you can swing it, you may be better off putting that money towards a new DLP rear projection NON RCA HDTV. I have had good luck with Toshiba sets for the last several years, and Consumer Reports seem to agree with me.
Posted on Apr 12, 2007
  • 1030 Answers
SOURCE: Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Posted on Feb 21, 2008
Shuttle83
  • 1139 Answers
SOURCE: RCA HD52W59 CONVERGENCE ISSUE
Hello n0lcl285,
I gave this advice before and I hope it helps you too.
You may not have to buy a new board. It just might be the Convergence Amplifiers that have gone bad. You may just want to replace them first and then see if it corrects your problem before getting the whole board. The convergence amplifiers are easily identified they are tow big black modules attached to a big metal frame called a heat sync, normally it will be located on the right rear section of the TV set looking at it from the back or it would be located in the middle rear of the set looking at it from the rear. In any even look for two big six sided black components with 21-22 pins, now this is the important parts some electronics parts stores sell what are called Convergence Kits (Yes this problem is so common that they have put kits together to repair this issue), they contain the two modules and the biasing resistors needed to properly do the job. You will have to order the kit for your make and model of TV if they do not have a kit, you will have to use a schematic diagram to find the values of the biasing resistors needed. Once you have the modules and the biasing resistors, you will have to de-solder the modules and the associated resistors and replace them with the ones you purchased. You will also need to detach the modules from the heat sink clean the heat sink (with alcohol) and then attach the new modules (with a new application of heat sink paste, which is the white stuff the you removed with the alcohol) with the screws you removed to detach the modules. Once the modules and biasing resistors are installed you will need to turn on the TV and then perform a convergence setup, your TV most likely will have an auto convergence alignment setup feature on the setup menu , use this to do the convergence alignment setup (check your users manual for help in doing this). The cost for this repair will be as follows:
2 STK392-1XX series Convergence Amplifiers $4.00-$15.00 USD Total $8.00 - $30.00 USD
9-10 biasing resistors $5.00-$10.00 USD (multipack) $15.00 USD
Solder $5.00 USD
Soldering Iron $20.00 USD
Silicone Heat sink paste $6.00 USD
de-soldering brade $5.00
The cost of materials will be about $81.00 on the high end.
The cost of a new board will be about $150.00 - $200.00 depending on the vendor.
You can buy replacement boards from a manufacture approved vendor outlet, go to the manufacture's site find support and parts they should have a listing of supported vendors. I would suggest calling the vendor and ordering from the phone asking them to send you an RMA for the part (board) this protect you from having them asses charges without delivery of product.
You will need the schematic diagram to help you install it schematics can be purchased at http://www.servicemanuals.net
for about $19.00 USD.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 19, 2008
SD Tech
  • 14553 Answers
SOURCE: rca p46813bl convergence problem bowed in the
OK., I know this set very well. It almost never has a convergence problem.
With the set unplugged, remove the back cover--there is a small circuit board mounted ABOVE the main boards--it is about 10 inches wide and 4 inches tall---On the far right side of it are several DIODES---two are much larger then the rest--what usually happens is one of the large diodes is shorted--5 dollar part---the board only has a few plugs and 4 screws that hold it in---easy to remove--check all the diodes(the two large ones first)
If either of the large diodes read like a fuse you FOUND YOUR TROUBLE.
LET me know if you need ANY help or Advice--I am here to help people---I have seen several sets identical to yours with the problem you describe.
Regards, SD TECH
Posted on Oct 07, 2009
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
Projector out of alignment
Ur convergence is dead,buy convergence kit use what inside that kit,U know how to solder right?Tries website Tv Repair World.com.
Sep 28, 2009 | RCA P61960 61" Rear Projection Television
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Bowed Picture
This is a convergence problem. If you can solder, you should be able to repair this yourself. Please update this to confirm the model as P52960 and whether or not you wish to attempt the repair and I will supply additional details and instructions.
Dan
Oct 06, 2008 | RCA P52960 52" Rear Projection Television
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
Feb 20, 2008 | RCA HD56W66 56" HDTV
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture too big for screen
if anyone has this p61960 television that does not work anymore, I am looking for parts for mine and would buy, please let me know, thanks
Oct 14, 2007 | RCA P61960 61" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
