Question about Hoover Washing Machines
Hoover washing machine shows lock symbol and won't start
SOURCE: machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Posted on May 15, 2009
SOURCE: Bosch classic 6 1400 express washing machine - key
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Posted on Oct 19, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
  • 662 Answers
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
  • 360 Answers
SOURCE: My mother accidentally pulled the
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Posted on Aug 07, 2011
Hoover Auto Washer 1000 A2100
Sounds like faulty door lock
Jun 19, 2013 | Washing Machines
Whirlpool washer won't start. Not a water problem. Door lock lift on or at times flashing. Think it's something to do with the door or panel.
At the right end of your panel you will find the 'end of cycle' symbol, to unlock keep this depressed for 3 seconds, this is the child lock feature. You do it again, and the machine locks.
Click if helped......
Apr 20, 2013 | Washing Machines
Cannot get rid of the lock symbol and it won't start even b4 the symbol appeared?
This sounds like a faulty door lock switch or a faulty main electronic logic board.When the door lock switch is faulty or opened it pauses the main board to allow the machine to stop working without switching off completely so that you don't lose the cycle when opening the door during a wash.But there should be a button to push to release the door lock when starting up the machine.if that doesen't work then there is a breakdown of communication from the door lock switch to the main logic board and visa versa if the board is faulty.If your machine is more than five years old then those two problems are the most common in those machines. Have a technician check it out.
Apr 15, 2013 | Washing Machines
Hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Sep 04, 2012 | Washing Machines
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
Apr 05, 2012 | Washing Machines
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
Key symbol showing machine will not start
Generic problem for all Bosch Washing Machines Key symbol showing machine will not start
Sep 11, 2009 | Bosch Washing Machines
Washing Machines Logo
194 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
