Question about JVC LT-17X475 17 in. EDTV LCD Television
JVC LT-17X475 cant change video inputs.
This has happened before, both by buttons on the tv or by remote i cant do anything, change input channel or volume. I think there is a board loose. I want to open and look around. Could this be just a soder point or is a board bad and need replaced?
  • 9 Answers
SOURCE: JVC GM-P420E Plasma no video green screen
the problem is with the micro processor on the back of the fx-1169a board (gm-p420ug) this is the board the inputs connect to . yours may be a diffrent p/n due to yours bein a "e" extention model. to repair this problem you need to remove the processor from the socket, remove the socket from the board and solder the processor onto the board. the processor is ic002 on the back side the problem is thermal in nature due to cold solder joints on the socket. i have fixed this problem many times by using this method.
Posted on Jan 28, 2009
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
SOURCE: Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Posted on Feb 20, 2009
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Posted on Mar 29, 2009
  • 105 Answers
SOURCE: No Picture
I am deeply sorry but you will need to replace the backlight bulbs. These are not available.
Look on Ebay for a 32" JVC with a broken LCD Screen. Buy it and use these bulbs to fix your TV. I am sure there will be a few good ones in the broken TV. It's that or list it on Ebay for $50 and expect to get about 200-300.
LCD Panel repair for this problem is $500 for parts so you are stick with repair yourself or sell.
Posted on May 27, 2009
  • 105 Answers
SOURCE: No Picture
Backlight Bulb is out.
You cannot purchase these as a spare part, you must purchase the complete backlight.
Backlight cost is more than or equal to a new TV
You may sell this TV on Ebay (list your exact symptom). Start at 100 you will get about 250. Take this money and buy a new TV.
LCD backlights don't fail often but when they do there are no part available to repair them so you get stuck buying the complete assembly part. This is more expensive than a new TV since LCD prices have dropped so much in recent years.
Posted on Jun 23, 2009
0 characters
1 Points
JVC LT 32E488
Unless this JUST started happening AND the TV worked previously, or you recently added a device to your set up, I am guessing that you simply are on the wrong input. For instance, I have a playstation connected to Video 2 and if my TV is set to Video 2 input AND my playstation is NOT on, the screen will be lit, but no picture. Make sure you are on the correct input.
Oct 26, 2013 | Flat Panel Televisions
I accidentally pressed a wrong button when I was changing back to TV after watching a video. then the screen became snowy and I'm unable to get back to TV mode. I need help!
Hello rgas,
do you know if you have cable or satellite? Look on your remote and for a button called input or source and click on it. Remember what input it is set on first then try changing through each input. See if you get anything. If nothing still, go back to the original input it was on and change the channel to channel 3. If you have cable or satellite, turn it on. If nothing appears, go to input/source scroll through each input and hopefully you should get a picture. Good luck.
Aug 30, 2011 | Flat Panel Televisions
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Flat Panel Televisions
How do i get to an hdmi channel?
Selects the signal input source for the television: VIDEO-1, 2, 3, 4 or 5 for video devices like
VCRs, DVD players, or camcorders.
Press the V1, V2, V3, V4 or V5 button
• When you return to TV mode, press the RETURN+/TV button or direct 10 key pad or CHANNEL
+/- button.
• You can also access by pressing the INPUT button on the side of the TV instead of the remote.
This was taken directly from the manual which you can download and view here:
Thank you and enjoy,
Mar 08, 2011 | JVC LT-42X688 42 in. LCD HDTV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Tv works jsut no pic black and white screen says weak or no signel?
If it says "weak or no signal", this means your are not showing the correct input or have no channels programmed.
To find the the correct video input:
1. turn On the device you are trying to see
2. press the [input] button on the side of the TV until you get a picture (wait 3 seconds between pressing the button)
You program the TV by accessing it in the User Menu.
Also, You may access the inputs using the TV remote. Each input button (V4 and V5) may need to be pressed muliptle time to access the picture . When you press this on the remote you will notice the input change from Composite 1, Component 1, S-Video. V5 will show composite 2 and component 2. Using the side panel allows youto scan all inputs in case you are not sure.
Jun 23, 2009 | JVC LT42P789 42 in. LCD TV
JVC 40 inch LCD digital inputs (1 and 2) no longer works. Standard video and component cable inputs work, but not HDMI. Please help
This TV has a sensor that deactivates the inputs when light is sensed. perform this procedure to correct it:
1. press "Sleep" button on the remote
2. while "Sleep timer 0" is showing, simultanuously press "display" and "video" button on the remote
3. you should be in the Service menu of the TV....if not you should do the steps again
4. select "self check" from the displayed options.
5. when the "self check" menu is displayed, Power off the TV.
6. unplug and replug the TV.
7. Check the digital input.
if the input never worked for you, it is possible that you have the DVD/Bluray/whatever set up incorrectly. I don't think this TV accepts 1080P resolution so make sure it is set to 1080i or lower
Jun 23, 2009 | JVC LT-40X776 40 in. LCD HDTV
My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Feb 01, 2009 | JVC LT-42X579 42 in. LCD TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Sony KDFE50A10 Just shows snow, buttons do not repond
Do you have the correct remote? That would be my first question. But most sony remotes will change channels and turn set on and off. Do you have the owners manual? If i'm not mistaken, that thing has a memory stick input doesn't it? Try that and let me know what happens. Thank you and good luck. Jay
Feb 01, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
JVC LT-17X475 17 in. EDTV LCD Television Logo
51 people viewed this question
Top JVC Flat Panel Televisions Experts
Are you a JVC Flat Panel Television Expert? Answer questions, earn points and help others
